Front bench/bed/dinette. 1973 220
Travco Model: 1969 270 with new brakes
Unread post by ptedrick » Sat Jul 03, 2021 11:15 am
I just bought the infamous 1973 Travco 220 with the modified front end and suspected Ford headlights. It is now parked at the end of my deck. I previously had an even more rare 1973 Travco built Sightseer with a 440 engine. It had the convertible passenger seat which was a bench, a bed, and a dinette. I finally figured out how to switch it back and forth but this one is different and is currently in a forward facing bench configuration with the dinette table removed. Can anybody coach me on the conversion process?
Re: Front bench/bed/dinette. 1973 220
Unread post by KB2CRK » Sat Jul 03, 2021 2:41 pm
Most of them flip over from forward bench to dinette bench. Maybe there is a latch that was added? to get it to lay down usually you have to lift it until you here the click and then lay it flat.
Unread post by ptedrick » Sat Jul 03, 2021 4:01 pm
I tried that and WD-40. Neither have worked so far. Tomorrow I will take a couple pictures and see if that is a help. The seat is in the way and I can't get the doghouse up.
Unread post by ptedrick » Sun Jul 04, 2021 4:11 pm
Forgot how to include picture
Unread post by ptedrick » Mon Jul 05, 2021 9:45 pm
My son either figured it out or or just applied sufficient muscle. It might have been the WD-40 kicking in. I can now get into my doghouse.
Return to “Travco 220”
