220 Standard carb adjustment
Unread postby bryanspoon on Sat Aug 30, 2014 11:24 am
My carb is running rich, blowing black soot out the back....the two barrel carb is in it and seems to be fine for me, I just want to slim it down. Anyway explain which screw is which to adjust to get this baby running better? Actually gets about 10mpg on the freeway now, but I'd like to fix this...Thanks!
bryanspoon
Travco Model: 220
Re: 220 Standard carb adjustment
Unread postby 77Travco on Tue Sep 02, 2014 9:01 pm
10 mpg is pretty good.
Is the air filter real dirty? That could cause it to run rich. Carbs don't just go out of adjustment... If you don't know how to fiddle with them then I would find someone who can. The norm is to screw the enrichner screws all the way in and then out 2 1/2 as a base setting. Otherwise grab a rebuild kit for it, download some instructions and have fun.
Unread postby bryanspoon on Tue Sep 02, 2014 10:15 pm
Thanks. The guy before me out it on. Is out richer?
bryanspoon
Travco Model: 220
Unread postby Acesneights on Wed Sep 03, 2014 8:10 pm
on the 2bbl IIRC out is leaner but it's been awhile. Just go a little at a time each way until it's running smooth. make sure the engine is good and hot and the choke is off. 10 mpg is about right for a 220. That is what mine used to get. an Aluminum intake and 4bbl will wake it up nicely.
Unread postby bryanspoon on Wed Sep 03, 2014 11:59 pm
Better mpg with a 4 barrel?
bryanspoon
Travco Model: 220
Unread postby 77Travco on Thu Sep 04, 2014 10:32 am
It is possible to get just as good or better mpg with a 4 barrel as long as you keep your foot outta it. The extra power of the secondary's will "wake it up" when you need to stomp on it.
Unread postby frank-id on Sun Sep 28, 2014 3:36 pm
The air idle screws are just for idle. The richness is controlled by the main jets. These jets can be replaced for a leaner fuel mix. Every carb has 6 systems. Frank
frank-id
Return to Travco 220
Users browsing this forum: No registered users and 6 guests
