What do I really have?
Travco Model: 220
Re: What do I really have?
Unread post by Fraynez » Mon Jun 29, 2015 8:01 pm
What I have is S1 from the battery to the cluster. A20 from the cluster to the Alternator and All the places A20 goes.
So Is my system charging through the ammeter?
I have a 72 wiring giagram that show it wired this way to the cluster.
This is pix for last post
Here is post of numbers on my block. Hoping you can tell me more.
Travco Model: 220
Unread post by Fraynez » Mon Jun 29, 2015 8:09 pm
any ideas would be greatly appreciated. Thank you
Travco Model: 220
Unread post by Fraynez » Mon Jun 29, 2015 8:19 pm
I almost forgot about this. Does this help in any way.
Plus does anyone know where to get parts for this stabilizer?
Unread post by Acesneights » Mon Jun 29, 2015 8:30 pm
What does the tag on the stabilizer say ?\nThat motor looks to me like a 440. If the distributor is in front toward the radiator, it's either a 440 or 413. If the distributor is in the rear it's a 318.\n\nDoes the Travco have disc or drum front brakes ? Post a picture of the front of it. Yes the charging system is through the amp Guage.\nBTW the AMP gauges rarely work and even when they do they are worthless. I put an Autometer voltage gauge in my Travco.
Unread post by Dave78Chieftain » Mon Jun 29, 2015 8:42 pm
Engine 6 T 440 T\n\n6 - 1976\nT - Built at Trenton factory plant\n440 - 440CI\nT - Truck (Truck means 440-3 not 440-1)\nThat info pulled directly from the 76/77 Service manual \n\nNot sure what the build date was.\n\n1973 Wiring diagram: http://dave78chieftain.com/73_Dodge_Wirin.html\n\nNeed the brand name off the leveling system to help with that (on control panel). Also model of leveler system if printed on control panel.\n\nIgnition switch: AUX - OFF - RUN (IGN 1) - START (IGN 2)\n\nDodge Electronic Ignition\n\nChrysler Electronic Ignition System Test
Last edited by Dave78Chieftain on Mon Jun 29, 2015 9:01 pm, edited 8 times in total.
Online
Unread post by KB2CRK » Mon Jun 29, 2015 8:42 pm
I read that wrong..... 440 T not 440 1,
Unread post by Dave78Chieftain » Mon Jun 29, 2015 8:59 pm
The ammeter was a weak point on the 73 and earlier Dodge platforms. The shunt resistor built into the ammeter burns out leaving you stranded. Dodge changed the design in 74 that uses a short section of wire in the alternator charge wire as a shunt monitor for the ammeter which is actually a millivolt meter. All modern day ammeters are based on the remote shunt design.\n\nDave
Travco Model: 220
Unread post by Fraynez » Mon Jun 29, 2015 9:17 pm
here are more pix of the stabilizer.
Here is a heater that way added on \n. Is it something i should fix up or put in new? pull levers to open and shut do not work. need grease?
Travco Model: 220
Unread post by Fraynez » Mon Jun 29, 2015 9:28 pm
Dave going to do ign test tomorrow will let you know how that works out. Thank you for your time.Thanks to everyone. Talk tomorrow. Good night.
Unread post by Dave78Chieftain » Mon Jun 29, 2015 10:18 pm
Return to “Travco 220”
