My 1975 Travco 270
Re: My 1975 Travco 270
Unread post by badbillybiker » Thu Nov 27, 2014 6:23 pm
here are the two fuel pumps that are very affordable. Don't remember the specs\nof either the Red or Blue pump. Affordable as in the ability to carry a spare...\nDo not like the manual engine diaphram pump or trust it.\nIf you run out of gas, just add more, let the electric pump bring the gas to the \ncarb and fire it up. No long time cranking... if it quits you know instantly\nwhat the problem is...The pressure regulator is just in case I have a problem \nof sorts and require or need. HTH\nBBB
Travco Model: Looking to buy one.
Unread post by fardav219 » Wed Jun 27, 2018 1:17 am
I am enjoying your site! Lots of hard work to refurbish these old Travco's but I think they are sure worth it when they"re done. thanks for sharing all your hard work!
