Rubber Mount Suspension
Unread postby bordoms on Sat Mar 03, 2018 10:39 pm
Im looking for new mounts for a rubber mount rear suspension on m 1969 Dodge Travco. I cant even find pictures of it. It looks like the rear end floats between rubber mounts. There is no springs at all.
bordoms
Travco Model: 1969 Travco 2+2 Mahal
Re: Rubber Mount Suspension
Unread postby KB2CRK on Sun Mar 04, 2018 10:33 am
Unread postby bordoms on Thu Mar 08, 2018 6:37 am
Has anyone purchased replacement suspension mounts and installed them?
bordoms
Unread postby KB2CRK on Thu Mar 08, 2018 7:14 am
The Mor/ryde is an aftermarket set up and I have only seen a few pictures with it on Travcos. There were a couple people on the Dodge Travco Facebook gorup that had them. Maybe one of them has changed the rubber spring out. Mor/ryde had a youtube page that shows how to replace the rubber blocks.
Unread postby bordoms on Thu Mar 08, 2018 7:39 am
Thank you very much!
bordoms
Unread postby raysimmons on Thu Mar 08, 2018 3:41 pm
I have replaced mine about 10 yrs ago and it was very easy. use never seize when reinstalling so 20yrs from now they will come off easier. mor ride stated that you did not need all the mounts as the new ones are stronger but I replaced them all anyway. if you haven't driven with them yet you will find it takes most of the sway out when YOU pass the big rigs doing 75 mph ! add the air bags to your front axel with about 15-20 lb of air and your love driving the twisty back roads again ! this suspension was installed at the factory (chrys) I believe, as on my original order form it was listed as an available chassis option along with the 70 gal fuel tank.
raysimmons
Unread postby bordoms on Wed Mar 14, 2018 9:18 am
Thank you!! Its nice to know the suspension will handle all the torque output of the 318.
bordoms
Unread postby raysimmons on Thu Mar 15, 2018 7:11 am
413 in my "mahal".. a real torque monster of an engine
raysimmons
Unread postby KB2CRK on Thu Mar 15, 2018 5:43 pm
Mor/Ryde has pictures of the suspension being installed on a small bus Chassis with a diesel. the diesel has a bit more torque than a 318....
Next
Return to Travco 270
Users browsing this forum: No registered users and 10 guests
