Painting Exterior
- Travco Model: 1973 dodge 270
Painting Exterior
Does anyone know the best way to paint the exterior? Does the original paint have to be removed before the new paint? If so, what is the best way to remove the original old paint? Any ideas or suggestions would be good thank you!
- Travco Model: 76 270 2+2 & 76 270
Re: Painting Exterior
Can you give more information? How do you plan to paint it? Roller? Brush? Spray gun? HVLP spray gun? They will all require a different answer. As for paint removal. If there is nothing wrong with the adhesion of the existing paint, it is better to leave it on. As long as you prep and clean the surface it will adhere.
- Travco Model: 1972 travco
Ive been looking at how to paint my 270. Im going to use rustoleum Topside Paint with a roller. Its a boat paint for fiberglass. I used it on a different project and it worked really well. They also have a primer that will fill in cracks. Im going to sand it all down with a DA, clean it and paint it. It wont look like a 20k dollar paint job but it will look good from 20 feet .
- Travco Model: 1971 270
\n\nI painted mine a couple years ago with Ace Hardwares Rust Stop paint. same as rustoleum but Ace can tint it whatever color you want. I used a DA to rough up the original gel coat and then put on several coats with a 6" foam roller. laid on nice and level. has held up very nice and I get tons of complimentslilivy wrote:Does anyone know the best way to paint the exterior? Does the original paint have to be removed before the new paint? If so, what is the best way to remove the original old paint? Any ideas or suggestions would be good thank you!
Valspar has an enamel hardener that works in that Rust Stop. Makes it even better. Better gloss and holds up better. Our Ace Hardware stocks it.
- Travco Model: 220
\n\nDid you sand off the gelcoat or paint over it? Primer?ontheroad wrote:Valspar has an enamel hardener that works in that Rust Stop. Makes it even better. Better gloss and holds up better. Our Ace Hardware stocks it.
\n\nI think you meant to ask "pjsrodshop" if he primed his. I haven't painted the outside of mine yet... But I wouldn't remove the gel coat if there wasn't anything wrong with it. And I would prime it, probably with an epoxy based primer. HTH.Woodsman wrote:\n\nDid you sand off the gelcoat or paint over it? Primer?
- Travco Model: 220
\n\nYep, wrong click.\n\nGelcoat has a lot of spider webs I'll have to router and fill.ontheroad wrote:\n\nI think you meant to ask "pjsrodshop" if he primed his. I haven't painted the outside of mine yet... But I wouldn't remove the gel coat if there wasn't anything wrong with it. And I would prime it, probably with an epoxy based primer. HTH.Woodsman wrote:\n\nDid you sand off the gelcoat or paint over it? Primer?
\n\n\nI have the same problem, more so on the back around the tail lights. That is what I plan on doing. Router the crack and fill it with 3M 08115 panel bond adhesive. Thats the best way I have found so far to fix them.Woodsman wrote:\n\nYep, wrong click.\n\nGelcoat has a lot of spider webs I'll have to router and fill.
- Travco Model: 220
[/quote]\n\nI was going to use gelcoat but the panel bond looks much easier to handle and apply. Good tip, thanks.ontheroad wrote:[quote="Woodsman]\nI have the same problem, more so on the back around the tail lights. That is what I plan on doing. Router the crack and fill it with 3M 08115 panel bond adhesive. Thats the best way I have found so far to fix them.
