Transmission line to radiator 8" rubber hose with fittings
Posted: Wed Oct 06, 2021 5:37 pm
by gojoe
Dealing with some leaks. Anyone have a part number for these or do I need to make em?
Re: Transmission line to radiator 8" rubber hose with fittings
Posted: Wed Oct 06, 2021 5:48 pm
If you have a hydraulic shop nearby they should be able to make some. If not some NAPA locations can make hoses up.
Posted: Fri Oct 15, 2021 5:57 pm
by gojoe
I tried a couple different Napa's and a hydraulic hose fabricator none of them could produce an inverted female with barbed or crimp on fitting. The clerk let me paw around some of the bins in the back and I ended up with some push on barbs and an adaptor to the female inverted. Have it installed but haven't road tested yet. Hope this clampless fitting holds.
