1972 Dodge Travco M375 Late Rear Brake Cylinders
Hello,\nI've been researching online for the definitive answer for what part # or #'s I need for the rear wheel cylinders. I have attached a pic of my rear right wheels. Any help in tracking down the correct cylinders is greatly appreciated. \nthanks,\nSean
Re: 1972 Dodge Travco M375 Late Rear Brake Cylinders
Napa numbers\n\nLeft 37669\nright 37670
This is for a Spicer 70HD rear axle in a M500 chassis but may work for you as well.\n\nWheel cylinder part numbers are:\nBendix\n33654 (1 3/8" Upper or Lower)\n33390 (1 1/2" Upper or Lower)\n -or-\nNAPA\nUP 37279 (1 3/8" Upper or Lower)\nUP 28661 (1 1/2" Upper or Lower)\n\nThe wheel seal for mine is part # 48811-C1 (NAPA part # 33136) This is for a Spicer 70HD rear axle in a M500 chassis.
