New to us 79 Travco/foretravel 320
Travco Model: 1979 320
Unread post by Blizzard of 79 » Fri Sep 25, 2015 9:53 am
Just picked this nice bus up. In really great original shape. I don't know much about these units but I am sure I will have questions. Did they all have central Vac or was that an option? Mine has airbags on the front suspension was that a factory option as well?\n\nThanks,
Re: New to us 79 Travco/foretravel 320
Unread post by KB2CRK » Fri Sep 25, 2015 4:46 pm
The vacuum is an option. I believe the air bags are an add on. Tons of information here on the forum and a lot of knowledgeable people.
Unread post by 77Travco » Mon Sep 28, 2015 4:31 pm
Looks nice! I'm guessing this coach is built on one of the last M600 chassis?
Unread post by Blizzard of 79 » Mon Sep 28, 2015 5:28 pm
I think so, but how do you tell for sure?
Unread post by Dave78Chieftain » Mon Sep 28, 2015 5:41 pm
Locate the Dodge VIN number plate. Will either be in the drivers area or in the radiator access area (drivers side firewall)\nFirst 2 digits of VIN\nM3 = M300\nM4 = M400\nM5 = M500 (19.5" tires with 5 lug nuts per tire)\nM6 = M600 (19.5" tires with 6 lug nuts per tire)
Unread post by Blizzard of 79 » Wed Sep 30, 2015 11:43 am
M 600 chassis it is. Is that a good thing or a bad thing? what did they go to afterwards? Drive train is 440 e with a 727 side loader I am told and Spicer rear end. Drum brakes on the rear and disc on the front. 6 lug rims 19.5 tires
Unread post by KB2CRK » Wed Sep 30, 2015 1:00 pm
Should be a Rockwell rear diff on the m600. M600 was the heaviest duty chassis for the dodge motor homes.
Unread post by 77Travco » Wed Sep 30, 2015 8:10 pm
Yep, rear axle will be a Rockwell with 488 gear ratio. Very heavy duty!\nThere was no "next chassis" as Chrysler dropped large truck chassis production in order to concentrate on passenger car production in order to save the company. The Travco motor coach company went the way of the dinosaur afterwards.
Return to “Travco 320/350”
