1973 318 iginition module, pick up coil, ballast resistor
Travco Model: 1973 270
Unread post by CharlesVarner » Sat Oct 13, 2018 12:11 pm
Can anyone direct me to where I can buy 1. a new ignition module, 2. pick up coil, 3. ballast resistor. I have a 1973 Travco with the 318. thanks, Charlie
Re: 1973 318 iginition module, pick up coil, ballast resisto
Unread post by KB2CRK » Sat Oct 13, 2018 2:58 pm
Any auto parts store should carry them. Chrysler used the same parts on most of their set ups back then. My 76 Travco with a 440 uses the same voltage regulator, ignition module, ballast resistor as my Slant 6 pick up. Pick up coil for the distributor might be different but it has been a long time since I have had to change one of those (as in the last time was on a 77 Charger back in 87).
Unread post by CharlesVarner » Sun Oct 14, 2018 5:07 pm
Thanks for the quick response. I will check out the auto parts store.
Unread post by KB2CRK » Sun Oct 14, 2018 5:19 pm
The parts store will not have it listed under the Motor home chassis unless you go to NAPA. You can find the parts anywhere else by telling them a Dodge D300 of the same year with the same engine.
Unread post by CharlesVarner » Sun Oct 14, 2018 5:50 pm
ok thanks for the good advice. Actually I posted my engine size wrong...it is not a 318...it is the 413.
Unread post by KB2CRK » Sun Oct 14, 2018 6:05 pm
For the 413 you may have to tell them a Dodge D500. Most of the 440 parts for a D300 should work also but there are some difference
Unread post by CharlesVarner » Sun Oct 14, 2018 6:17 pm
ok...thanks again!
Return to “Engines”
