'72 270 w/ 413 - Intermittent Power Loss
Travco Model: 1972 D270 413
Unread post by broomeju » Tue May 22, 2018 8:55 am
I have been chasing a problem that has me scratching my head.\nThe engine will lose power.\nIt will not stall completely but it will only idle.\nIf I get off the gas for about 10 seconds and then get back on it again it'll run well for several more hours.\nit never happens out on the road when cruising (even when going up long hills when engine systems would seem most "stressed") \n\nIt appears to only happen when:\n1) the engine is hot\n2) the engine has been running at load but then have slowed to an idle (ex. stopping to get gas/lunch/errand)\n3) typically happens when accelerating but sometimes happens under light load, too\n\nWhat I've done:\n1) cleaned fuel tank and lines and installed fuel/water separator (like on a boat - quart size filter element)\n2) installed new mechanical fuel pump\n3) rebuilt carb (Holley - set fuel levels, etc.)\n4) replaced old coil with new one ( this one did not require ballast resistor)\n5) cleaned ground where ECM unit mounts\n\nAny ideas what to check next ?
Re: '72 270 w/ 413 - Intermittent Power Loss
Unread post by 77Travco » Tue May 22, 2018 9:27 am
Do you have an EGR valve? Mine was hanging open at times when coming to a stop and caused an engine stall. I ended up blocking it off.
Unread post by broomeju » Tue May 22, 2018 9:51 am
Nope, no EGR valve on this old girl. \nThanks for the suggestion!\nI can not tell you how much I appreciate the assistance received from this forum.
Online
Travco Model: 1972 travco
Unread post by dirtydeno » Tue May 22, 2018 4:17 pm
This sounds to me like you are boiling gas in the carb or in the gas line. Check your gas line and move it away from heat. At load (driving) you are moving enough gas that it dose not boil but when you slow down the lower volume of gas heat soaks and boils.
Unread post by 77Travco » Thu May 24, 2018 9:56 am
Do you run an electric fuel pump near the tank to push the gas up to the mechanical pump?
Unread post by broomeju » Fri May 25, 2018 2:16 am
Thanks so much!!!!!\n\nSteel fuel line between mechanical fuel pump and carburetor was touching water pump body,etc. \n\nPulled fuel line up and away from hot surfaces, wrapped in with split open old water hose and problem is gone.
Online
Unread post by dirtydeno » Fri May 25, 2018 8:58 am
No problem glad to help!\n\n
broomeju wrote:Thanks so much!!!!!\n\nSteel fuel line between mechanical fuel pump and carburetor was touching water pump body,etc. \n\nPulled fuel line up and away from hot surfaces, wrapped in with split open old water hose and problem is gone.
Return to “Engines”
