Re: avco diesel conversion
Unread postby 77Travco on Wed Aug 10, 2016 4:47 pm
You have a front axle in mind for the 4x4 setup yet? I'm curious to see what you use.
Unread postby gon2sea on Wed Aug 10, 2016 8:03 pm
Yes, a dana super 60 out of a 2006 or newer f450 /f550, its wider than the other dana 60's and much stronger than the standard dana 60, not that the standard dana 60 is weak as it is rated at 6000lbs. the tube wall thinkness and diameter is bigger than the standard 60, the ball joints / knuckle assemble is quite a bit bigger and it also has bigger ujoints.
i will have to make wheel adapters to go from 10 lug to the motorhome 6 lug BUD pattern i am running. i just got some nice 19.5 ALCOA's to upgrade the look. ill use a NP263 electric shift transfer case.
gon2sea
Travco Model: Avco grand lodge
Unread postby 77Travco on Thu Aug 11, 2016 11:18 am
Sounds like you have a plan! I would personally stick with 10 lug 19.5 wheels that bolt straight onto the axle... maybe swap the rear axle to match. Otherwise carry 2 spares or maybe none at all.
Unread postby el_pistolero45 on Tue Mar 27, 2018 6:49 pm
This is a Great Story with a fantastic hook in it! I've been a Cummins "B" Motor fan for 25yrs. I've got a 94 12v with 5spd that I'm saving for a similar project down the road. Your engineering has given me too many ideas to sleep tonight! Thanks for sharing! I'm following this thread until you start another project! :D
el_pistolero45
Travco Model: none yet
Unread postby 77Travco on Tue Apr 03, 2018 2:09 pm
gon2sea hasn't logged on since August of 2016... maybe he moved on to other projects but I hope he will update us someday.
Previous
Return to Engines
Users browsing this forum: No registered users and 7 guests
