413-1 timing chain replacement?
- Travco Model: 1971 Grand lodge
I have my radiator off and I'd like to do as much now as I can.\n\nI was thinking to change the timing chain but I can't find it from JC whitney\n\nanyone know where I should look?\n\n1971 Dodge AVCO grand lodge\n\n413-1 engine\n\nI'm also trying to find a water pump but none of the ones I see line up with the bolt pattern
Re: 413-1 timing chain replacement?
\nthanks so much, how did you find those numbers? Do you have the old books?Dave78Chieftain wrote:See your other post
If you visit Dave's website you will find that he is a plethora of information when it comes to Dodge chassis motorhomes.
For 75 and earlier:\nBest version for Service manual: 69-75 Service Dodge P/N 81-690-1162 \n\nBest version for parts: 69 - 77 Parts Dodge P/N 81-690-131\n\nSources:\nmoparmanuals\nEBAY\nfaxonautoliterature\nCWVRV Store\n\n69-71 Dodge truck service manual also covers M300/M375. The M300 was an outgrowth of the P300 Forward Control chassis (used 62 - 68) and parts are normally interchangeble in the 69-71 era.
