Found a leaky caliper. Kudos to daves page.
Re: Found a leaky caliper. Kudos to daves page.
Unread post by KB2CRK » Tue Jan 12, 2016 4:04 pm
Brakes are done. All bled out and ready to go. Pedal was low so took a quick look at the rear adjustment. Had to adjust them quite a bit and the pedal came up nicely. I will take it for a test drive tomorrow after getting a manual choke in it.
Unread post by Acesneights » Tue Jan 12, 2016 9:51 pm
can you post the brand and parts numbers for the calipers ?
Unread post by KB2CRK » Wed Jan 13, 2016 7:17 am
The calipers are Raybestos\nPart # FRC 4041 and FRC 4042\nPads were also Raybestos PGD 87M
Unread post by 77Travco » Thu Jan 14, 2016 8:28 am
Thanks for sharing!
Unread post by KB2CRK » Thu Jan 14, 2016 9:16 am
77Travco wrote:Thanks for sharing!
\n\nNo problem. The more shared info the better it is for all of us.
Unread post by diskman » Sun Feb 21, 2016 6:06 pm
KB2CRK wrote:Done except for bleeding the brakes. Temp is dropping and the cold concrete was getting to me. I will let it gravity bleed tomorrow while I replace the generator bracket and install the manual choke. Final bleed will be when my wife gets home tomorrow evening.
\n\n\nPssshhh.. Concrete.... I been playin in the cold mud all morning laying on cardboard and styrofoam messing with exhaust and evaluating my holding tank mess on 270. LOL.. tip: Run to the nearest home improvement store and pick up a sheet of that pink 1 inch foam. Cut in in half (4x4). You now have a comfy place to lie down under the vehicle or to sit on.\n\nThanks for the front brake pics and info! PO replaced my fronts, but the flex lines look baaaaaaad..
Unread post by KB2CRK » Sun Feb 21, 2016 6:23 pm
There is a listing it the parts section here fro the hoses.
Return to “Brakes”
