1975 Travco 270 no rear brakes
- Travco Model: 1974 270
Re: 1975 Travco 270 no rear brakes
That's right. It's so fresh fluid will replenish both cylinders at the same time.
well at some point I'm gonna put together a powerbleeder but I was lcuky this time. After I changed the front rubber lines and re bled I have a good solid pedal now. I don't like the brake pads though. NAPA has two grades, these were the cheaper but I went with them because they were in stock but pay the freight for the better ones. These are Bonded not riveted and I do NOT like bonded pads.
Just realized I never updated this. I ended up bleeding it the old fashioned way. It works, just takes a little longer. I work on alot of Military trucks with air over hydraulic so a power bleeder is on my wish list still but the old fashion way works fine. The new master works correctly and solved my problem.
I'm just glad that I have the hydroboost setup!
Me Too....\n\n\n\n\n\n\n\n\nme
