Rear brake work on my 270
Re: Rear brake work on my 270
Unread post by 77Travco » Tue Mar 26, 2013 3:06 pm
The lug nuts take a 1.5" socket or tire tool. They spin real easy once they are loose.\nI will take a picture of and measure the spindle when home later today.
Unread post by Acesneights » Tue Mar 26, 2013 9:12 pm
I had a few snap on my 73 270 that I used to have. Luckily local Truck Parts place had them.
Unread post by 77Travco » Wed Mar 27, 2013 8:12 am
I just looked up the torque specs for M500 chassis Lugnuts... 450-500 ft lbs! :shock: \n\nAlso - here is a pic of the spindle with measurments as made by me with a square and straight edge.
rcb
Travco Model: Looking for 210
Unread post by rcb » Wed Mar 27, 2013 8:25 am
Thanks! I greatly appreciate it. \n\n450 to 500 foot pounds! Better start carrying one long tire iron! LOL.
Unread post by Acesneights » Wed Mar 27, 2013 11:09 am
Guess i'll be breaking out my 3/4 impact gun.
Unread post by Acesneights » Wed Mar 27, 2013 11:11 am
77Travco wrote:Well, I finally started working on my brake issue. The rear brakes seemed non-existent and I had a wheel cylinder leaking on the drivers side.\nIt was a real pain to bust loose the lugnuts with the factory tire tools. It is definetely not a job for light weights. (pun intended... I weigh 230 lbs) I had to use my entire body weight to loosen those lugs. ;) \nOnce I got the wheels off, it was apparent that the rear brakes haven't been making proper contact with the drums for some time. I pulled both wheel cylinders and took them down to my local NAPA. Mine are the 1 3/8" versions which cost $27 a piece. They had to order them from Houston and all parts will be here sometime this week. I also ordered a wheel bearing seal that turned out to cost $29 !\nWheel cylinder part numbers are:\nBendix\n33654 (1 3/8" Upper or Lower)\n33390 (1 1/2" Upper or Lower)\n -or-\nNAPA\nUP 37279 (1 3/8" Upper or Lower)\nUP 28661 (1 1/2" Upper or Lower)\n\n\nThe wheel seal is part # 48811-C1 This is for a Spicer 70HD rear axle in a M500 chassis.
\n\nWhat brand part# is that seal ?
Unread post by 77Travco » Wed Mar 27, 2013 12:53 pm
Wheel seal that came out had part # 48811-C1 on it. NAPA gave me part # SKF 33136. I also found seal part # SKF 33136 on Rockauto.com.\nI know for a fact that the NAPA part fits because I installed one on the drivers side... I hope to get the Rockauto part in the mail today or tomorrow.\nThe NAPA cost me $29... I found a "closeout" seal on Rockauto for $6 but they have more for $20. The Napa seal was made in USA... not sure about the other one yet.
Unread post by 77Travco » Wed Mar 27, 2013 1:07 pm
Acesneights wrote:Guess i'll be breaking out my 3/4 impact gun.
\n\nYeppers... you're gonna need it! :D
Unread post by 77Travco » Fri Mar 29, 2013 12:25 am
well, I got everything on the passenger side back together tonight. Here is my lugnut technique, I stand on a ladder and put it to them!
Unread post by Acesneights » Fri Mar 29, 2013 2:39 pm
Done that a few times.\nHey I'm in a jam. I got mine ripped apart too. Were both your upper and lower wheel cyls the same ?\nBoth my upper and lower are 1 3/8 bore but the outside casting looks a little different. Which part # was right for you and did it fit upper and lower ?
Return to “Brakes”
