Rear brake work on my 270
Re: Rear brake work on my 270
Unread post by Acesneights » Tue Apr 09, 2013 9:04 pm
That link did not give me any specifics. How did you look it up ?
Unread post by 77Travco » Wed Apr 10, 2013 9:40 am
I googled RAYBESTOS 88PG.\n\nI know the Chrysler part # is 4026636 and Bendix is RAF88.\n\nThe NAPA part # was SS88 but now that doesn't work.
Travco Model: 1972 270
Unread post by rjsdotorg » Tue Feb 13, 2018 10:03 am
Looking for the seals myself now. I see that some have the extra lip, I assume to sling oil in case of failure.\n\nBTW, I bought one of the cheap torque multipliers on Ebay; OMG is it easy. You could easily remove the nuts with one hand, or snap them off tightening...
Unread post by 77Travco » Tue Feb 13, 2018 12:40 pm
rjsdotorg wrote:Looking for the seals myself now. I see that some have the extra lip, I assume to sling oil in case of failure.\n\nBTW, I bought one of the cheap torque multipliers on Ebay; OMG is it easy. You could easily remove the nuts with one hand, or snap them off tightening...
\nYes, I believe the torque multiplier method is the easier way to go!
Unread post by Acesneights » Wed Feb 14, 2018 11:07 am
I just Park my 5 ton next to it and use the robotool. I wish they made these in 12v...\n\nhttps://www.ebay.com/itm/24-28v-RoboImpact-3-4- ... Swv0tU8Nhw
Unread post by rjsdotorg » Sat May 26, 2018 10:52 am
BTW, from the look of this\nImage\nthe axle is actually different than mine; the 71 has 3 bolts top and 3 bottom - not evenly spaced.\nThe self adjusters would swap!\n\nThe evenly spaced bolts would allow many of the new aftermarket disk conversions.
Unread post by raysimmons » Sun May 27, 2018 7:29 am
just a little fyi, make sure you "re torque" those lug nuts after about 100 miles or so and then again after a few more hundred miles. they WILL loosen up ! whether from a little dirt or alignment of the wheels as they roll. after 20 yrs and 3 sets of tires i'm speaking from experience.
Unread post by rjsdotorg » Sun May 27, 2018 9:12 am
raysimmons wrote:just a little fyi, make sure you "re torque" those lug nuts after about 100 miles or so and then again after a few more hundred miles. they WILL loosen up ! whether from a little dirt or alignment of the wheels as they roll. after 20 yrs and 3 sets of tires i'm speaking from experience.
\n\nI'll bet. I bought a torque multiplier, which every truck owner should carry, so ~8lbs input is 480 output, easy-peasey.\nI also read some industry reports that excess paint on the wheel-hub mating and under-torquing are the main causes of broken lugs and lost wheels. It is the friction of wheel to hub that holds the wheel on, not the lugs per se.\n\nI also discovered that I'm shopping for new tires. The Michelins have cracks on the inside sidewalls and are 10yo.
Unread post by rjsdotorg » Sun May 27, 2018 9:16 am
I'll also check the balance of the hubs while the seals are off and the bearings wiped from grease. It is actually a FSM mention for tires, and I found the right front hub was way out.\n\nThe bearings are so smooth that a 9/16" nut will cause the 50lb drum to turn if you tape it to one side.
Unread post by raysimmons » Sun May 27, 2018 3:22 pm
I've had one front drum out of balance for the last 20 yrs. any one know of where in new England they can be balanced ? I've been attaching weights till it gets close with the wheel off the ground. not perfect but it took the low speed wobble out. my tires dry rot before they wear out anyway.
Return to “Brakes”
