Rear brake work on my 270
Re: Rear brake work on my 270
Unread post by Acesneights » Tue Apr 09, 2013 9:04 pm
That link did not give me any specifics. How did you look it up ?
Unread post by 77Travco » Wed Apr 10, 2013 9:40 am
I googled RAYBESTOS 88PG.\n\nI know the Chrysler part # is 4026636 and Bendix is RAF88.\n\nThe NAPA part # was SS88 but now that doesn't work.
Unread post by 77Travco » Tue Feb 13, 2018 12:40 pm
rjsdotorg wrote:Looking for the seals myself now. I see that some have the extra lip, I assume to sling oil in case of failure.\n\nBTW, I bought one of the cheap torque multipliers on Ebay; OMG is it easy. You could easily remove the nuts with one hand, or snap them off tightening...
\nYes, I believe the torque multiplier method is the easier way to go!
Unread post by Acesneights » Wed Feb 14, 2018 11:07 am
I just Park my 5 ton next to it and use the robotool. I wish they made these in 12v...\n\nhttps://www.ebay.com/itm/24-28v-RoboImpact-3-4- ... Swv0tU8Nhw
Unread post by raysimmons » Sun May 27, 2018 7:29 am
just a little fyi, make sure you "re torque" those lug nuts after about 100 miles or so and then again after a few more hundred miles. they WILL loosen up ! whether from a little dirt or alignment of the wheels as they roll. after 20 yrs and 3 sets of tires i'm speaking from experience.
Unread post by raysimmons » Sun May 27, 2018 3:22 pm
I've had one front drum out of balance for the last 20 yrs. any one know of where in new England they can be balanced ? I've been attaching weights till it gets close with the wheel off the ground. not perfect but it took the low speed wobble out. my tires dry rot before they wear out anyway.
Return to “Brakes”
