1972 270 hydroboost conversion
Unread postby dirtydeno on Mon Mar 12, 2018 8:45 am
I instlled a hydroboost on the 270 yesterday. I used a hydro boost off of an 06 E450. I mounted the booster as low as i could on the original bracket so the resorvoir would clear the floor.
I had to add add some metal to the brake arm to move the plunger hole to a spot where it would get a full stroke and the lever throw was not to long. It took a few holes to get it right.
The entire bracket then just bolts back up. I drilled a hole in the floor for adding brake fluid and cut the carpet in a flap so it is hidden. I then removed all of the hydro vac system. I just need to have 2 power steering lines built and connect my lines. I also need to install a proportioning valve.
dirtydeno
Travco Model: 1972 travco
Re: 1972 270 hydroboost conversion
Unread postby 77Travco on Tue Mar 13, 2018 9:19 am
I know there are some members on this forum that would definitely be interested in this. Please be sure to post up your road test results!
Unread postby dirtydeno on Wed Mar 28, 2018 8:33 am
I got all the new hydro boost lines made along with all new braided hoses and all new 1/4" tube. I used about 35 feet of brake tube. I used a chevy proportioning valve for disc/drum with a built in residual pressure valve. It turned out pretty nice. I still need to connect the wire from the old block to the new one. I have not yet driven it do to a gas tank issue but this weekend it should be on the road.
dirtydeno
Unread postby dirtydeno on Sat Mar 31, 2018 8:14 pm
I just drove the travco for the first time. It brakes great. It stops very quickly and feels similar to e450s i drive at work. I can brake and turn at the same time and the stock pump does well. I did not drive it with the hydrovac brakes so i cannot really compare it to the before but i am very happy with it. Also it hasnt been driven since the 90s and it did great. Very well built rig.
dirtydeno
Unread postby rjsdotorg on Sat Mar 31, 2018 11:02 pm
So was this same as my '71, and the master now faces rearward instead?
That's what I wondered most about converting the pedal-lever.
rjsdotorg
Travco Model: 1972 270
Unread postby dirtydeno on Sat Mar 31, 2018 11:26 pm
rjsdotorg wrote:So was this same as my '71, and the master now faces rearward instead?
The master faces rearward opposite of a regular vehicle but the original also faced rearward. The pedal is still the same.
dirtydeno
Unread postby rjsdotorg on Sun Apr 01, 2018 10:34 am
Ahh, that must have been the switch-over year to rearward. Mine is "early" 71.
rjsdotorg
Unread postby datsit on Wed Apr 04, 2018 7:25 pm
Your 72 should have drums on the front ?
datsit
Unread postby rjsdotorg on Wed Apr 04, 2018 8:06 pm
datsit wrote:Your 72 should have drums on the front ?
My 71 does, and I think 72-73 "should" as well, if OEM.
rjsdotorg
Unread postby dirtydeno on Thu Apr 05, 2018 4:54 pm
my 72 had drums but i swapped the front axle to disc.
dirtydeno
Return to Brakes
