1971 M375 single system rear rebuild
Travco Model: 1972 270
Unread post by rjsdotorg » Tue Jun 05, 2018 11:22 pm
A few pics of the process.\n\nFirst, remove wheels almost effortlessly in a few minutes\n
\n\n\nAs the drum was removed, saw broken spring and other leaks and problems\n
Re: 1971 M375 single system rear rebuild
Unread post by rjsdotorg » Tue Jun 05, 2018 11:25 pm
This side had a new seal, but slaves leaked\n
\n
Unread post by rjsdotorg » Tue Jun 05, 2018 11:27 pm
Slaves honed and polished.\n
\n\nThis one isn't quite done.\n
\n\nUsed 240 hone, then 320, 400, 600 1500 paper \npiston to wall clearance should be <=.006"\nassemble with brake system assembly lube\n\n\n1-3/8 cups then installed\n
Unread post by rjsdotorg » Tue Jun 05, 2018 11:31 pm
axle had a wear groove from original seal and oil after 60k miles.\n
\n\nPolished the surface and checked the location; the original seal was pressed all the way into the hub.\nNew National 456648 seals will be tapped just flush and so the lips will ride on clean steel.
Unread post by rjsdotorg » Tue Jun 05, 2018 11:35 pm
All the parts had to be degreased, power washed, acid rust treated, and heat paint sprayed.\nLoose assembly:\n
\n\nself adjusters are smooth and clean\n\nAssembled with spring kit from Alretta Truck parts; spendy but the only ones in existence.\n
\n\nThe springs that hook around the casting are a bitch to snap in.
Unread post by rjsdotorg » Tue Jun 05, 2018 11:42 pm
Best order of assembly:\n
  1. \n
  2. adjuster screws and slides etc\n
  3. heat shields and cylinders\n
  4. shoes and retainer nuts and washers\n
  5. adjuster arms and springs\n
  6. return springs\n
  7. connecting line
Unread post by rjsdotorg » Tue Jun 05, 2018 11:45 pm
a lower casting\n
\n\nan upper\n
\n\n
Unread post by rjsdotorg » Tue Jun 05, 2018 11:53 pm
Some notes on parts and such\n
Travco Model: 1972 travco
Unread post by dirtydeno » Wed Jun 06, 2018 8:43 am
Looks good, this is on my to do list in the next month or so.
Unread post by rjsdotorg » Wed Jun 06, 2018 9:14 am
dirtydeno wrote:Looks good, this is on my to do list in the next month or so.
\n\nIf you don't have a torque multiplier or 500lb impact, I cannot recommend it enough.\nThe springs also definitely require big proper spring tools.
Return to “Brakes”
