Part#s Sticky
Unread postby Acesneights on Wed Jan 23, 2013 12:25 pm
Let this be a sticky for up to date Brake part #s .
Re: Part#s Sticky
Unread postby Acesneights on Wed Jan 23, 2013 7:48 pm
This company sells the Hydravac/boost units. Hopefully this link will sty active.
http://www.autoatlanta.com/centric/sear ... app=707527
I believe the above part # is for single Circuit. I would confirm before ordering. I posted the 518016 A-1 Cardone below. I can confirm that is correct.
Also I have been told that this company is excellent with Travco brake parts and knowledgeable.
http://alretta.com/
Re: Part#s Sticky
Unread postby Acesneights on Sun Jan 27, 2013 10:46 am
This website has as much info a I have ever seen regarding Dodge Chassis brakes setups. I have been trying to reach the site owner for permission to copy it but for now here is the link.
http://dave78chieftain.zxq.net/
Re: Part#s Sticky
Unread postby 77Travco on Sun Jan 27, 2013 11:00 am
Good information... I know this will help me in the future!
Re: Part#s Sticky
Unread postby Acesneights on Sun Jan 27, 2013 11:10 am
Yeah, I can't see any place on his site to contact him so I was gonna look up the domain reg. I want to get his permission to copy the info here in case his site ends up like Mytravco did.
What a shame that was. it was a good site.
Travco 270 front brake line part number
Unread postby Acesneights on Mon Jun 24, 2013 7:24 pm
Front rubber lines for Disc setup.
NAPA
Travco 270 rear wheel seal part number
Unread postby Acesneights on Sun Jul 27, 2014 3:12 pm
1975 Travco 270 M500 rear wheel seals NAPA 33136. I would assume this is on all the 270 M500's
Travco Brake Booster Hydrovac
Unread postby Acesneights on Sun Aug 03, 2014 6:29 pm
Brake Boosters for Dual circuit brakes(front disc, rear drum) Mid 70's.
I have both a 1975 270 and a 1974 220. Both had the same booster.
The part number in A-1 Cardone is 518016. NAPA NBB 518016.
Rockauto carries the Cardone.
*Note*- The booster listed above is the correct one but the mounting bracket on the rear is different. You can fab a bracket to mate to it or do what I did and just swap the rear cover from your old booster to your new one. They are interchangable.
Re: Part#s Sticky
Unread postby 77Travco on Thu Aug 07, 2014 8:54 am
I dug up these parts numbers for M500 chassis brakes. I can't guarantee them all to be current or correct.
Wheel cylinder Part #'s:
Chrysler - 3621892 Upper & 3641893 Lower (1 3/8"), 2954347 Upper & 2954348 Lower (1 1/2")
Bendix - 33654 (1 3/8" Upper or lower), 33390 (1 1/2" Upper or lower)
NAPA - UP37279 (1 3/8" Upper or lower), UP28661 (1 1/2" Upper or lower)
CARQUEST - EW77072 (1 3/8")
Raybestos - WC-37279 (1 3/8")
Wagner - F113064 (1 3/8")
Master Cylinder Part #'s
Chrysler - 4031345 (1976-up)
Bendix - 11583 (76-up)
NAPA - UP39012 (76-up), TS101583 (76-up)
CARQUEST - E84058 (76-up)
Raybestos - MC-39012 (76-up)
Wagner - F84058 (76-up)
Rear Shoes 15X4
Chrysler - 4026636
Bendix - RAF88
NAPA - SS88
Raybestos - 88PG
Front Pads
Chrysler - 3744500, 4186999
Bendix - MKD87
NAPA - TS7020M, UP7020M
Raybestos - PGD87M
Wagner - MX7020AR, MX87, PD7020AR, PD8
Re: Part#s Sticky
Unread postby Dave78Chieftain on Sun Mar 01, 2015 5:57 pm
My site is now at http://dave78chieftain.com/. Moved to a pay site due to unreliability of free site.
I am 63 however I have no intention of taking it down for a long time.
Dave
Dave78Chieftain
Return to Brakes
