Re: M500 Brake Drum Removal
Unread postby Acesneights on Thu Feb 25, 2016 9:07 pm
That is a dust shield. Most floating axles have them. Yo can do the seal without removing it.
Unread postby Dodgy71 on Thu Feb 25, 2016 9:16 pm
How do you remove the seal with that type of configuration? I typically use a seal puller "pry" tool on smaller automotive stuff. Does this one require a tool that "pulls" the seal by pulling on the bearing relative to the drum thereby pulling the seal?
Sorry if this is getting off the topic of this thread...
Dodgy71
Travco Model: 1971 270
Unread postby Acesneights on Sun Feb 28, 2016 7:06 pm
I usually use a piece of wood and drive the bearing and seal out from the other side. In other words I stick my piece of 2x2 in through the side that faces out and smack the inner bearing towards the seal and the whole seal and bearing comes out. Just make sure there is a clean rag under it or someone helping to catch the bearing so it doesn't fall on the ground and get full of dirt.
Unread postby Acesneights on Sun Feb 28, 2016 7:08 pm
Another way although the drum is kinda heavy is to pull the outer bearing while the hub is on the spindle then thread one of the axle nuts back on and just yank the drum and hub towards you and that usually pops it out also.
Unread postby KB2CRK on Sun Feb 28, 2016 8:51 pm
Acesneights wrote:Another way although the drum is kinda heavy is to pull the outer bearing while the hub is on the spindle then thread one of the axle nuts back on and just yank the drum and hub towards you and that usually pops it out also.
This is what I have done for years.
Unread postby sakurathesteamqueen on Fri Jul 14, 2017 11:00 am
Hi I have a 74 Travco 270 and my passenger side rear adjusters are frozen up does any one have any tricks to geting it loose? I tried rust buster but no luck, and saw a video just now showing a guy with a torch heat it up for a minute at most and get it freed up with some vicegrips but not sure if ill be able to do that since the adjuster wheel is abit larger than his. Also I think Im missing the piece that sits in the dust shield of each side of the cylinders and makes contact with the shoes, does anyone know what this is called? I tried looking at davesplace but didnt see that part listed, or if it was there wasnt a pic with it. Any help would be much appreciated!
sakurathesteamqueen
Travco Model: 1974 Travco 270
Unread postby Dave78Chieftain on Fri Jul 14, 2017 5:40 pm
Do you have Twinplex
or the Duo-Servo Brakes?
Dave78Chieftain
Unread postby sakurathesteamqueen on Sat Jul 15, 2017 10:46 am
I believe it is the twinplex.
sakurathesteamqueen
Unread postby rjsdotorg on Sat May 26, 2018 5:47 pm
Acesneights wrote:That is a dust shield. Most floating axles have them. Yo can do the seal without removing it.
The seal lip on mine is larger diameter than the inside of the oil slinger/shield.
I could slot the shield, I suppose...
I'll have to double-check.
rjsdotorg
Travco Model: 1972 270
Unread postby rjsdotorg on Sat May 26, 2018 6:35 pm
Ahh, they came out with a wood drift - they just fit out past the oil slinger.
rjsdotorg
Previous
Return to Brakes
