1972 - 270 front brake hardware kit part #?
Unread post by kingdome627 » Sun Oct 02, 2016 10:04 pm
[attachment=0]Screenshot_2016-10-02-20-01-20.png[/attachment \n\nHaving a hell of a time finding the correct front drum brake hardware for my 72 270. The manual says its a bendix duo-servo but its a completely different set up then whats on mine. I have attached a pic of mine.\nThanks,\nSean
Re: 1972 - 270 front brake hardware kit part #?
Unread post by KB2CRK » Mon Oct 03, 2016 8:31 am
Looks like a very common set up. Definitely Duo servo. Almost looks like a GM set up. I worked on many a car that used that set up in the rear.
Unread post by kingdome627 » Mon Oct 03, 2016 10:32 am
\n\nhttp://dave78chieftain.com/M375Late.html\n\nDave's site shows part # UP 2243 or H7199 which is incorrect. (See image) Its completely different hardware.
Unread post by KB2CRK » Mon Oct 03, 2016 10:43 am
That set in the picture from Daves page looks like the rear springs for the ford 14X3 shoe set up.
Travco Model: 1972 Mahal
Unread post by Travco72 » Tue Oct 04, 2016 10:52 am
The kit part number H7139 that Dave lists on his site for the M-300 1969-71 (Front 12.12" x 2"; Rear 13" x 2.5") looks like the right kit compared to your photo. The kit services both front wheels I believe... so the springs shown and hold down hardware match. On my 1972 Travco the chassis was actually a 1971 and my front wheel looked identical to your photo.\n\nMight be worth a deeper look at that part number.
Travco Model: 1971 270
Unread post by Dodgy71 » Sat Oct 29, 2016 1:50 pm
I have the same setup, and started the complete brake rebuild this summer.\nI got mine from Geoffrey at Alretta Truck Parts. He knows these old Dodge truck chassis brakes very well. As I recall, the front hardware set was not too pricey, but other parts can be. See contact info below.\n\nAlretta Truck Parts\nGeoffrey Rosenberg\nbrakeparts@mac.com\n(508) 788-9409 main
Unread post by Dave78Chieftain » Sat Sep 02, 2017 10:34 am
I am fairly sure that is the early Chrysler model 12.12"x2" brake system. The Bendix H7139 kit should work.\nImage\n\nThe H7199 Kit is for the later Bendix model 14.5"x 2.5" drum.\nImage\n\nDave
Return to “Brakes”
