1972 - 270 front brake hardware kit part #?
Unread postby kingdome627 on Sun Oct 02, 2016 10:04 pm
[attachment=0]Screenshot_2016-10-02-20-01-20.png[/attachment
Having a hell of a time finding the correct front drum brake hardware for my 72 270. The manual says its a bendix duo-servo but its a completely different set up then whats on mine. I have attached a pic of mine.
Thanks,
Sean
kingdome627
Re: 1972 - 270 front brake hardware kit part #?
Unread postby KB2CRK on Mon Oct 03, 2016 8:31 am
Looks like a very common set up. Definitely Duo servo. Almost looks like a GM set up. I worked on many a car that used that set up in the rear.
Unread postby kingdome627 on Mon Oct 03, 2016 10:32 am
http://dave78chieftain.com/M375Late.html
Dave's site shows part # UP 2243 or H7199 which is incorrect. (See image) Its completely different hardware.
kingdome627
Unread postby KB2CRK on Mon Oct 03, 2016 10:43 am
That set in the picture from Daves page looks like the rear springs for the ford 14X3 shoe set up.
Unread postby Travco72 on Tue Oct 04, 2016 10:52 am
The kit part number H7139 that Dave lists on his site for the M-300 1969-71 (Front 12.12" x 2"; Rear 13" x 2.5") looks like the right kit compared to your photo. The kit services both front wheels I believe... so the springs shown and hold down hardware match. On my 1972 Travco the chassis was actually a 1971 and my front wheel looked identical to your photo.
Might be worth a deeper look at that part number.
Travco72
Travco Model: 1972 Mahal
Unread postby Dodgy71 on Sat Oct 29, 2016 1:50 pm
I have the same setup, and started the complete brake rebuild this summer.
I got mine from Geoffrey at Alretta Truck Parts. He knows these old Dodge truck chassis brakes very well. As I recall, the front hardware set was not too pricey, but other parts can be. See contact info below.
Alretta Truck Parts
Geoffrey Rosenberg
brakeparts@mac.com
(508) 788-9409 main
Dodgy71
Travco Model: 1971 270
Unread postby Dave78Chieftain on Sat Sep 02, 2017 10:34 am
I am fairly sure that is the early Chrysler model 12.12"x2" brake system. The Bendix H7139 kit should work.
The H7199 Kit is for the later Bendix model 14.5"x 2.5" drum.
Dave
Dave78Chieftain
Return to Brakes
