part number for replacement rim stud?
- Travco Model: 1973 270
Hi, I need to replace one stud from the drivers side front wheel, so reverse thread. Its off a '73 270. I dont have the stud with me otherwise I would hit a truck parts store and just show it to them. It would save me about 3 hours of driving out to where my coach is stored if someone could tell me a part number or reference. \n\nThanks in advance\nDavid
Re: part number for replacement rim stud?
I had found a link using google about a year ago. I can't remember where it was but they had the studs and nuts inner and outer for the rear, Front left and right handed thread. If I can find it again I will post it here.
Awesome, tx
If you cant find LH threaded stud, I would just swap them all over to RH thread.
I'm in need of rear inside wheel studs ?? any part # would help, I'll get 2 right & left threads for each side.
They are common. Any heavy truck parts place like Fleetpride can match up your old ones.
need rear wheel stud specs - - wheel stud measurements thick
I'm in need of the specs on rear wheel studs, on the M-375 chassis I believe they are .086 ?? I have found rear brake drums for my Travco ?? the wheel stud hole is 0.88-0.89" I can't find any specs on the studs 69 M-375 HELP ?????
I don't know the spec. I usually just brought an old one down the to the parts place.
I need to know the stud size (collar) to see if they will fit the rear brake drums before I commit to $$$$ for these drums ??
