19.5's on a 66
- Travco Model: 270... I think
19.5's on a 66
Hey all, looking for some advice on an axle swap. I'm thinking about picking up an Isuzu NPR for the axles, engine and trans swap in a 66. Since the '66 has low fenders, I'm wondering if anyone has tried putting 19.5's on one of these. I realize the width of the axle has a lot to do with this, but I thought I'd check here for advice before diving into this.
Re: 19.5's on a 66
...or I suppose I could buy this;\n\nhttp://www.ebay.com/itm/1972-TRAVCO-DODGE-CHAS ... r\n\nLooks like someone already put a newer set of axles under what is left of this Travco. Kind of sad really.
Re: 19.5's on a 66
Those are original axles under that Travco. The 220 was on the M300 chassis which had the 8 lug Wheels
Re: 19.5's on a 66
wow, 8 lugs were stock? That's very cool. Almost worth picking this up.
Re: 19.5's on a 66
Those axles are not rated for the heavier 270. IIRC the 220 had a 3500lb front axle as compared to the 4000lb front axle of the 270. The rear axle is most likely a Dana 70 which was rated somewhere around 7500lbs as compared to the Dana 70HD which is rated for 10,000lbs.
