Board index » Maintenance » Steering,Suspension and Tires
Post here for Steering ,suspension and tires discussion
19.5's on a 66
Unread postby Franknsr on Wed Jul 05, 2017 9:51 pm
Hey all, looking for some advice on an axle swap. I'm thinking about picking up an Isuzu NPR for the axles, engine and trans swap in a 66. Since the '66 has low fenders, I'm wondering if anyone has tried putting 19.5's on one of these. I realize the width of the axle has a lot to do with this, but I thought I'd check here for advice before diving into this.
Franknsr
Travco Model: 270... I think
Re: 19.5's on a 66
Unread postby Franknsr on Thu Jul 06, 2017 9:39 am
...or I suppose I could buy this;
http://www.ebay.com/itm/1972-TRAVCO-DOD ... dz&vxp=mtr
Looks like someone already put a newer set of axles under what is left of this Travco. Kind of sad really.
Franknsr
Re: 19.5's on a 66
Unread postby KB2CRK on Thu Jul 06, 2017 5:41 pm
Those are original axles under that Travco. The 220 was on the M300 chassis which had the 8 lug Wheels
Re: 19.5's on a 66
Unread postby Franknsr on Thu Jul 06, 2017 10:34 pm
wow, 8 lugs were stock? That's very cool. Almost worth picking this up.
Franknsr
Re: 19.5's on a 66
Unread postby KB2CRK on Fri Jul 07, 2017 6:49 am
Those axles are not rated for the heavier 270. IIRC the 220 had a 3500lb front axle as compared to the 4000lb front axle of the 270. The rear axle is most likely a Dana 70 which was rated somewhere around 7500lbs as compared to the Dana 70HD which is rated for 10,000lbs.
Return to Steering,Suspension and Tires
Users browsing this forum: No registered users and 5 guests
