1976 axles in a 1972
Unread postby 72twodoor270 on Sat Sep 16, 2017 10:19 pm
I got the front axle out from under the 76 today. wasn't as hard as I thought it would be. The rig does have to go up in the air a bit to "roll" the axle assembly out with the shock towers still attached, but other than that it was pretty straight forward.
I intended on harvesting the frame mounts but the drivers side storage compartment prevents access to one of the rivets along the side of the frame. I was only able to cut the front mount rivets completely.
I plan on dragging the shell out of the shop and blocking it up for rear axle removal. Then I will load up both assembly's on a trailer and power wash them until all the grim is gone.
I was also able to harvest the mounting brackets and plates for the steering box and master cylinder assembly incase dodge made big changes between 72 and 76.
72twodoor270
Re: 1976 axles in a 1972
Unread postby 77Travco on Tue Sep 19, 2017 9:52 am
Looks like fun!
Unread postby 72twodoor270 on Tue Sep 19, 2017 8:50 pm
I started on the rear axle tonight. Although there is less moving parts, it went a lot slower. bigger bolts, tighter nuts, lots of dirt, crud, and spiders.... I managed to get all of the bolts out except one. its pinched in its hole pretty tight.
If you have never pulled the entire axle assembly out before, be warned- the rear leafs have a lot of spring left in them. at quitting time tonight I have the passenger side unbolted and now the springs are pushed up through the plywood floor. I wish I would of thought of that before I let the body down to move the jack. I would of put a block in there.
I will jack up both sides and block them up and hopefully get the pressure of the remaining bolt and then figure out a way to slide the axle out from under the rig.
I will take some pics next time.
72twodoor270
