Re: Removing steering box?
Unread postby rjsdotorg on Sun Jan 21, 2018 10:07 pm
nice
rjsdotorg
Travco Model: 1972 270
Unread postby rjsdotorg on Tue Jan 23, 2018 12:52 am
What is the part store number (or wherever) for the box?
OReilly's etc are clueless and can't look up the OEM Saginaw number.
Considering just replacing the top seal and the pump seal, we'll see.
rjsdotorg
Unread postby KB2CRK on Tue Jan 23, 2018 5:25 am
Did you check the parts list here on the forum. I got the part number from the travco group on Facebook and I thought I had the number here somewhere. I am not sure if it changed between yours and a 76 though.
Unread postby rjsdotorg on Tue Jan 23, 2018 11:07 am
From
viewtopic.php?f=54&t=1029
CARDONE 27-7501
looks like mine
(cheap https://www.carid.com/cardone/remanufac ... -7501.html)
and my FSM says it is a Saginaw 708, but no one cross references the exact #, so we'll see. I'll look again and call NAPA, the warehouse here has a lot of old books.
Only 60k miles on the rig, and when full the steering sounds and feels fine, so it might just be dry seals, for now, unless someone ran it dry for a while and did subtle damage.
rjsdotorg
Unread postby rjsdotorg on Tue Jan 23, 2018 8:55 pm
Got most of the front end off...
The sawsall went right through the short weld and we lifted the combo out, after pulling the column.
The puller wouldn't fit between the arm and the box, but a few hammer taps and it loosened up.
I couldn't find a part number for the pump, yet, anyone? It did leak a little.
PS fluid was a little dark, so I'm replacing everything, and putting a filter in the return line.
Shoes, slaves and lines had been redone at some point recently, but RF drum is BADLY out of balance (not the tire) which loosened the bearings a tad and wore the seal a little too. All to be replaced. Interesting that the RF spindle looks new.
Rods all feel snug and stiff.
Turns out I could have pulled the column and the top seal below the snap ring, but the rest really should be done anyway.
rjsdotorg
Unread postby rjsdotorg on Wed Jan 24, 2018 11:43 pm
I got a NAPA box part #39-1038
https://www.napaonline.com/en/p/PNB391038
the only difference I see is that the input has a wide groove instead of a recess, for the pot joint clamp bolt.
At oreilly I got a pump 732-2123
Plus a filter for the line. More work tomorrow.
rjsdotorg
Unread postby rjsdotorg on Fri Jan 26, 2018 11:17 pm
Pics of new PS parts.
The high pressure hose had a pinhole leak - glad I tested it. New one on order.
I weighed the box - 55lbs with bracket!
rjsdotorg
Unread postby Acesneights on Fri Feb 02, 2018 6:43 pm
was the box bad ? Most of the time just needs a stub shaft seal. That can be replaced without removing the box.
Unread postby rjsdotorg on Fri Feb 02, 2018 10:43 pm
Not particularly; but the high pressure line was, and the fluid looked like motor oil.
I replaced it all - hopefully reassembled next week.
rjsdotorg
Previous
