1972 270 axle swap
Travco Model: 1972 travco
1972 270 axle swap
Unread post by dirtydeno » Mon Feb 26, 2018 8:54 am
I swapped the axles in my 270 and i thought i would put some info on it here. The donor was a 1978 georgie boy motorhome with a dodge chassis. The original plan was to swap the hubs with the 8 lug dana 70 but they did not fit the dana HD so swapped in the entire dana 70. The axle was a direct fit. Both axles had the same diameter 35 spline axles. The only difference i see is the axle tube diameter and some bearing diameters.\n
\n
\nNext i swapped in the front axle but it wasn't a direct fit. I originally wanted to swap only the 8 lug hubs and disc brakes but the backing plate mounts were not the same so i swapped the entire axle. The leaf springs on the travco are 3"s wide and the leaf springs on the donor axle were 3.5 wide. I had to egg out the the axle center pin a 1/4" on each outer side to fit the travco spring width. The shocks on the donor axle mount to a plate on top of each lea spring. I swapped those plates onto the travco springs wich also helped take up the slack of the ubolt width. The axle then bolted right up.\n
\n
\n
\nMy plans for next weekend are getting new brake lines made and im installing a hydro boost.
Re: 1972 270 axle swap
Unread post by 77Travco » Wed Feb 28, 2018 4:52 pm
Sweet!\nDid the steering linkage bolt right up?
Unread post by Acesneights » Wed Feb 28, 2018 9:36 pm
I thought about doing this to my old one but with F550 Axles with rear disc.
Unread post by dirtydeno » Thu Mar 01, 2018 8:47 am
The steering was identical to the old axle and bolted right up.
Unread post by 77Travco » Thu Mar 01, 2018 12:11 pm
dirtydeno wrote:The steering was identical to the old axle and bolted right up.
\n\nVery good to know!
Travco Model: 1972 270
Unread post by rjsdotorg » Wed Mar 07, 2018 12:26 am
Did you lubricate the springs?\nA mechanic friend swears it makes a real difference.
Unread post by dirtydeno » Thu Mar 08, 2018 8:51 am
Nope.
