1972 270 axle swap
Unread postby dirtydeno on Mon Feb 26, 2018 8:54 am
I swapped the axles in my 270 and i thought i would put some info on it here. The donor was a 1978 georgie boy motorhome with a dodge chassis. The original plan was to swap the hubs with the 8 lug dana 70 but they did not fit the dana HD so swapped in the entire dana 70. The axle was a direct fit. Both axles had the same diameter 35 spline axles. The only difference i see is the axle tube diameter and some bearing diameters.
Next i swapped in the front axle but it wasn't a direct fit. I originally wanted to swap only the 8 lug hubs and disc brakes but the backing plate mounts were not the same so i swapped the entire axle. The leaf springs on the travco are 3"s wide and the leaf springs on the donor axle were 3.5 wide. I had to egg out the the axle center pin a 1/4" on each outer side to fit the travco spring width. The shocks on the donor axle mount to a plate on top of each lea spring. I swapped those plates onto the travco springs wich also helped take up the slack of the ubolt width. The axle then bolted right up.
My plans for next weekend are getting new brake lines made and im installing a hydro boost.
dirtydeno
Travco Model: 1972 travco
Re: 1972 270 axle swap
Unread postby 77Travco on Wed Feb 28, 2018 4:52 pm
Sweet!
Did the steering linkage bolt right up?
Unread postby Acesneights on Wed Feb 28, 2018 9:36 pm
I thought about doing this to my old one but with F550 Axles with rear disc.
Unread postby dirtydeno on Thu Mar 01, 2018 8:47 am
The steering was identical to the old axle and bolted right up.
dirtydeno
Unread postby 77Travco on Thu Mar 01, 2018 12:11 pm
dirtydeno wrote:The steering was identical to the old axle and bolted right up.
Very good to know!
Unread postby rjsdotorg on Wed Mar 07, 2018 12:26 am
Did you lubricate the springs?
A mechanic friend swears it makes a real difference.
rjsdotorg
Travco Model: 1972 270
Unread postby dirtydeno on Thu Mar 08, 2018 8:51 am
Nope.
dirtydeno
