Board index » Maintenance » Steering,Suspension and Tires
Post here for Steering ,suspension and tires discussion
Bag lifts
Unread postby rcb on Wed Apr 10, 2013 10:03 am
For those that have them, how much can you raise your rear axle... if you want to?
Among other reasons, one of my the main contributing factors in seeking a 210/220 is the rear overhang and my incredibly steep driveway... in the neighborhood of 10 degrees (19% grade). We get farm equipment up and down it, but our pull behind has WAY too much overhang.
So, I was contemplating if I could really get some temporary lift out of air bags on a 270, I might be able to pull it off.
rcb
Travco Model: Looking for 210
Re: Bag lifts
Unread postby Acesneights on Wed Apr 10, 2013 10:51 am
I'll let you know when I pump mine up but IIRC it wasn't much.
Re: Bag lifts
Unread postby rcb on Wed Apr 10, 2013 11:36 am
Thanks. Yeah... probably not much, but it's a thought. I'd be interested in that 270 in Toledo, but it MUST make it up the driveway. The pull behind is at my uncles but any travco I want at my own place.
rcb
Re: Bag lifts
Unread postby Acesneights on Wed Apr 10, 2013 11:43 am
The other issue 270's face it the long wheelbase and low hanging outlet for the holding tank
Re: Bag lifts
Unread postby rcb on Wed Apr 10, 2013 11:51 am
On the top the grade is much more gradual. The bottom is rough be the road is dead level and instantly jumps to the grade. I've thought about cutting more into the hill, but the erosion wouldn't be worth it. (we live at the top of a bluff)
rcb
Re: Bag lifts
Unread postby 77Travco on Wed Apr 10, 2013 2:45 pm
Not sure why, but the suspension on my 270 seems to sit rather high. No bags or anything.
Re: Bag lifts
Unread postby rcb on Wed Apr 10, 2013 5:32 pm
Higher than most I've seen. Maybe newer springs?
What I'm thinking is if I can, with bags, drop the front and raise the rear, I might be able to just get up the driveway. These have 5 feet of overhang past the rear tires right?
rcb
Re: Bag lifts
Unread postby 77Travco on Wed Apr 10, 2013 8:05 pm
From my mudflaps to my rear bumper measures about 6' - 10".
Re: Bag lifts
Unread postby rcb on Sat Apr 13, 2013 2:34 pm
Well, after remeasuring it appears its about a 25% grade. I'd need to get at least 2' of clearance between the ground and the lowest point at the rear of a 270. I think a 210 or 220 is still the way to go for me. That one in toledo is so tempting but probably best to be patient.
rcb
Re: Bag lifts
Unread postby Acesneights on Mon May 13, 2013 5:48 am
My bags lifted it about 2 inches at 80 psi.
Return to Steering,Suspension and Tires
Users browsing this forum: No registered users and 5 guests
