Re: 19.5 WHEELS...FOUND THEM !!!
Unread postby Dodgy71 on Tue Dec 01, 2015 12:36 am
Were the M500 wheels a 4.75" offset, like the WNR89340 from WheelsNow?
Does this offset cause the rear dual wheel's tires to rub against each other, with tires that are available today (radials) {77Travco's comment}? I'm asking because I need to make the transition from the 17" split ring to the 19.5" tubeless, and if I spend the big bucks, I want to make sure that I get it right...
Dodgy71
Travco Model: 1971 270
Unread postby 77Travco on Tue Dec 01, 2015 10:33 am
I do not know the offset of the 19.5" wheels... (width is 6") hopefully someone can chime in or I can measure my spare wheel if needed.
Here are a few pics of the same wheels with the 225/70R19.5 tires and then with the factory correct size 8R19.5 tires. Both sizes are radials. Notice how much skinnier and taller the 8R19.5's are.
Unread postby 77Travco on Tue Dec 01, 2015 10:37 am
Here are a few pics of the wheels without tires. Not sure if that will help you or not.
Previous
