Re: Easy Lug nut removal
Unread postby 77Travco on Thu May 19, 2016 2:11 pm
When you buy the stud, post up a part number. Hopefully it's not a big deal to find one.
Unread postby Zed on Mon Nov 21, 2016 1:12 am
Can OP post up the math formula he used to figure out the amount of torque needed in foot inches to get a specific torque in foot pounds out of this unit? I just bought one and I have completely taken all the drums off to inspect and clean the brakes and I need to re torque everything.
I think this unit is a 1:78 ratio drive so to achieve 450 foot lbs I would divide 450 by 78 which gives me 5.7 (rounded up) which converted to foot inches would be 5.7 x 12 which gives me 68.4 foot inches to achieve 450 foot pounds on the other end. Is this math correct?
Thanks.
Zed
Travco Model: 270 Mahal
Unread postby KB2CRK on Mon Nov 21, 2016 6:34 am
I don't remember the formula right now. I think I divided 500 by the reduction and came out with a very low ftlbs number. I then used an online converter to get the inch lbs. I believe for 500 ft lbs it was 76 in lbs so I think your conversion is close if not right.
Unread postby Acesneights on Wed Nov 23, 2016 8:39 pm
Too bad our Travcos are not 24v. I have one of these for my 5 ton. it works awesome.
http://www.ebay.com/itm/Roboimpact-Robo ... 75&vxp=mtr
Unread postby badbillybiker on Wed Nov 23, 2016 9:27 pm
CURIOUS... I acquired a 24 volt wheel chair charger under forgetable circumstances ages ago and never used it...... Wouldnt one runnning from the travco genset power the 24v charger to operate a 24v piece of equipment?...
maybe thru a 2 - 12volt battery bank? btw, i am a electrically challenged person...2btw, i too got one of those multipliers but never took it out of the box/carton...
Unread postby KB2CRK on Thu Nov 24, 2016 9:07 am
badbillybiker wrote:CURIOUS... I acquired a 24 volt wheel chair charger under forgetable circumstances ages ago and never used it...... Wouldnt one runnning from the travco genset power the 24v charger to operate a 24v piece of equipment?...
I have at least had it out of its box. Tried it even. One hand on the crank and I can spin the lugs off. This was after tightening them with a 4' breaker bar with all 260 lbs of my weight on it.
Unread postby badbillybiker on Thu Nov 24, 2016 9:56 am
As I am constantly on the hunt for Travco part numbers..
has anyone seen the part number for that stud posted yet?
Unread postby badbillybiker on Thu Nov 24, 2016 10:05 am
As I am constantly on the hunt for more Travco part numbers..
Has anyone seen the part number for that stud posted about yet?
Be nice to have a spare or two to put into my "new" parts bin...
Presuming it should be a low cost item, I'll take two...
Previous
