Easy Lug nut removal
Unread postby KB2CRK on Tue Jan 19, 2016 1:32 pm
Just got this tool today and it works. A bit slow but easy lug nut removal and comes with the sockets for the 1 1/2" lug nuts and the 13/16" inner nuts for the rear. I could not believe how easy it was with the provided handle to get the nuts loose.
Ebay link
http://www.ebay.com/itm/111724653743?_t ... EBIDX%3AIT
A simple torque multiplier but a lot easier than a 4' breaker bar.
Re: Easy Lug nut removal
Unread postby 77Travco on Fri Jan 22, 2016 9:41 am
Never seen one until recently... have those always existed? My big cheater bar works for me but I gotta admit that I would like to try one of those. At least for loosening the lug nuts.
Unread postby RobC on Fri Jan 22, 2016 1:29 pm
I just ordered one. The guy that put my wheels on last definitely over torqued them I can get most off but one or two on each wheel won't budge with my NAPA flex wrench and cheater bar. My only other option was to get the tire guy to come back out for $100/hour door to door.
I would much rather have this tool on board so I can do it myself.
RobC
RobC
Travco Model: 1976 270
Unread postby KB2CRK on Fri Jan 22, 2016 3:14 pm
77
It took all of my 260 lbs on the end of my 4' breaker bar to get Nessies lug nuts loose when i did the front brakes. This tool does it with one hand with the supplied handle. If I did the math correctly 77 inch lbs of torque on the input would set the lugs to 500 ft lbs. it comes with a straight shaft for spinning the lugs loose once broken free.
Unread postby RobC on Fri Jan 22, 2016 5:17 pm
Great find KB2.
My rim repainting project went on hold since I could not get my wheels off. I should be back in the game when my lug wrench shows up!
I had a mishmash of tires on my rig with three new toyos and three last leg tires. Two blew just sitting in the driveway! I need to get them off so I can get three new matching Toyos from Les Schwab.
Again thanks for the tip.
RobC
RobC
Unread postby badbillybiker on Thu Jan 28, 2016 9:14 pm
How can they afford free shipping on what that thing weigh's?
Unread postby KB2CRK on Fri Jan 29, 2016 8:27 am
badbillybiker wrote:How can they afford free shipping on what that thing weigh's?
Shows you how much some sellers are overcharging for it. May be going for bulk sales with a lower profit margin.
Unread postby badbillybiker on Fri Jan 29, 2016 1:22 pm
point well taken...but...how many travco owners are willing
to buy that Budd unit... I dont think with so many going to pushers
they are wanting to change their own tires...
Unread postby KB2CRK on Fri Jan 29, 2016 3:31 pm
It also works on heavy equipment and tractors. I could see many a small farmer getting one of these for use on their stuff.
Unread postby RobC on Tue Feb 02, 2016 3:21 pm
Mine showed up yesterday. I couldn't wait so I put on my head lamp and started in my otherwise frozen lugs.
Came off like butter.
This thing weighs probably 25 lbs so it is kind of unwieldy under the wheel wells but using a jackstand to get it in place worked great.
The Chinese instructions are hilarious.
Looks like the limit is 100 nm on the input handle which is about 75 foot/lbs. I am keeping my 4 foot breaker and Budd to set the torque on the bolts so I know I am right around 450-500.
I highly recommend this tool. $80 bucks with free shipping. I saw others on line for $200. Did not do any research on them though.
RobC
RobC
Next
