Best clearance lights
- Travco Model: 1975 320
A PO has replaced all the clearance lights on our 320 with a generic trailer side marker light.\nThe oval shaped two bulb type.\nAnyone know of a close match to the original lights?
1975 Travco 320
Re: Best clearance lights
My clearance light front and rear are the 2 bulb type... I am pretty sure they are original to the coach. I had to replace two of the rear ones... I just picked up a couple of single bulb units from CarQuest auto parts here in town. They are just as bright as the two bulb units without going to the LED look.\n\nIn the picture below the new lights are on either side of the center one.
I wanna put Mack Bullet style on mine from an old R Model. on mine.
That would look really cool! I looked at some similar lights when I was at the parts store but I was in a hurry to get on the road and didn't want to change them all out at the time... not to mention the cost.
Yeah the Mack ones are big bucks...
I went to work on a few of mine that were out and really the factory ones are the wrong lights anyway as they have no ground wire. All Travco did was stick a stripped ground wire under the screw. IMHO any lights used should have an independent ground wire.\nhttp://www.bigrigchromeshop.com/Merchant2/merc ... /CTGY/LCLK
When I replaced two of my rear clearance lights, there was a hot and a ground wire. I guess the grounds all tie to the metal skeleton frame but not sure.
\nhello were you able to get these lights. If not you need to check sites like ebay to get close match of these lights.FSJNut wrote:A PO has replaced all the clearance lights on our 320 with a generic trailer side marker led light.\nThe oval shaped two bulb type.\nAnyone know of a close match to the original lights?
I'm not sure what the original lights looked like. If anyone has a pic of what they think are original lights, please post.
1975 Travco 320
I know the Travco in my Avatar had the original lights but that was a 70.
