Turn signals and running lights
Unread postby RobC on Tue Apr 28, 2015 1:10 pm
Got my turn signals and head lights to work. No running lights or ID/tag lights yet. Still need to check the running lights themselves.
I know this is somewhat mundane for some of you but for a mediocre electrician like me I am totally psyched I figured it out using the schematic, the rats nest of wires in the rig, etc. ripping the floor out sure made it easier to isolate, assess and replace wires underneath!
Rob
PS: I also found the chrome bezels for the headlights and turn signals in a box the PO had stashed a bunch of towing stuff in. This means I am refurbishing the existing lights/bezels instead of going with new bigger rubber grommet turn signals.
I am making good progress on my rig as of late.
Re: Turn signals and running lights
Unread postby Acesneights on Tue Apr 28, 2015 7:57 pm
I hear ya. Mice ate the wire going up to my clearance lights and I just did not feel like dropping the panels again. I tapped into power from the cigarette lighter/ant amp and put a lighted switch up there for my clearance lights.
Unread postby RobC on Wed Apr 29, 2015 11:33 am
The wiring diagram shows a tell-tale three way junction with no connector that feeds the whole clearance light system.
got a good/bad feeling about that junction. Checking it out today. So far all of my electrical woes have been corrosion/bad connectors.
My wife asked me how I can pour over the diagrams for hours- and map out these systems in my head.
I told her it is kind of like meditation. Total immersion to the point you can't think about anything else while diagnosing the system.
She doesn't get it. Must be a guy thing.
Rob
Unread postby 77Travco on Wed Apr 29, 2015 4:31 pm
Glad your making progress!
Unread postby badbillybiker on Wed Apr 29, 2015 9:13 pm
being electrically challenged, am I to presume you have a junction but no connecting feed?
Possible it pulled loose after 40 years of bouncing and "kind of" retracted to a position you cannot see????
Wonder if when the ligfhts are on if that missing wire has a bare hot end???/ curious...
Might be a good thing as now you might be inclined to run a seperate "hot" wire and use it for power and blinking the markers in thanks for whatever reason... Thats how mine are going to redone..All the semi's I ever drove had a toggle switch on the dash for flashing high beams and markers... IMO/fwiw
Unread postby RobC on Wed Jun 24, 2015 12:23 pm
Turn signal update:
my side turn signal markers were full of mud and water so removed them drilled out the corroded steel holes for both turn signal and parking lights to an aftermarket socket size. Worked great. It was a pain in the ass drilling the goofy shaped signal fixture but worked out. I know have working turn signals all around.
Running lights still elude me.....
Rob
Return to Electrical
