Modern GenSet upgrade? Share your info.
Unread postby Raccoon on Sun Jun 07, 2015 8:16 pm
Hey everyone, I was just curious to know if anyone out there has upgraded or replaced their stock GenSet with something modern? If so, what was your experience and do you have any suggestions on what units are ones to look at and what ones to avoid.
Also, post any pictures of your system and set up if you have any.
Raccoon
Travco Model: Looking to buy a pre-70 Travco
Re: Modern GenSet upgrade? Share your info.
Unread postby Acesneights on Mon Jun 08, 2015 6:59 pm
Actually the Older CCK and NH Onans that came in these rigs are nearly indestructible and very reliable No electronics. If I was gonna go newer I think the only thing I would even consider would be a Honda RV genset. They pop up on CL every now and then.
The genset in mine was actually from my Father's 1970 . It is a 1969 Onan 4.0 cck.
Unread postby Raccoon on Mon Jun 08, 2015 7:14 pm
Thanks for the info Aces. The only reason I ask is because I am looking at a Travco that has been completely gutted with the exception of the motor and drivetrain. I have been researching what other people have done in regards to alternative GenSets in the case that I can't locate a good, running Onan unit. In the case that I can't find a decent Onan unit, are there any other generators that you've had experience with or others that you know of?
Raccoon
Unread postby KB2CRK on Mon Jun 08, 2015 9:09 pm
I wish I could help but the original Onan 6.0 NH Power Drawer still runs well in our 76. It did need a new control board but mechanically has no problems.
Unread postby Acesneights on Mon Jun 08, 2015 9:09 pm
I had a Travco that I put a Kohler in.. If you poke around CL though Onans are usually not too hard to find. Stay away from the Emerald Series. They had some issues. The older ones are better. Generac makes RV gensets too but IMHO Generac is the Hyundai of generators.
Return to Electrical
