Neutral Safety Switch
Posted: Tue Jun 30, 2015 4:28 pm
by RobC
Lo and behold after sitting for a few months I was not getting any juice to the starter as of yesterday. I am getting ready to fire up my beast with the rebuilt TQ on top but not go.\n\nIt will crank in Neutral but not in Park. Sounds like the Neutral safety switch should be making contact on both the Neutral and Park position.\n\nI am hoping it is just the switch and not the linkage inside.\n\nAnybody experienced this?\n\nRobC\n\nPS Manual says pull the plug and inspect to make sure the contacts are centered on the hole in Park and Neutral. My tranny is going to get rebuilt here pretty soon but I sure would like to know why no Park starting.
Re: Neutral Safety Switch
Posted: Wed Jul 01, 2015 3:50 pm
Let us know, I have never personally messed with it. It might be on the shifter ???
Posted: Wed Jul 01, 2015 5:22 pm
by RobC
Figured it out.\n\nThere are two mechanical contact points inside the transmission attached to the shifter lever mechanism. When in Park or Neutral the contact points touch the center pin on the neutral safety switch grounding it to the transmission case and completing the circuit to the starter relay and allowing the starter relay to do its job. \n\n"Full power to the starter Scotty"\n\nIn any other position R D 1, 2 or 3 there is no contact, no ground and no go.\n\n"I'm givin it all she's got Captain... ya can't change the laws of physics...."\n\nThe switch only completes the circuit to the starter relay so you can shift all you want while its running.\n\nThe fix was to clean all the dirt and oil and crap off the selector lever area on the drivers side of the tranny. It was pretty gnarly down there (**** with Simple green, toothbrush and follow with some carb cleaner). I then "aggressively" put the beast into and out of park a few times. the Park position is all the way back on the tranny lever and It was probably just not quite getting there (see **** procedure above).\n\nProblem solved. Bottom line is that the selector lever pin and seal are probably worn out and a rebuild will fix that but for now I am mobile.\n\nTwo birds with one stone: I have a tranny fluid leak somewhere down there in that area. Enough to drip a few times a day onto the exhaust pipe which upon start and warm up makes for a very dramatic smoke show for about 5 minutes in the driveway. The leak is one of the following:\n1) forward oil cooler line fitting\n2) Kickdown adjustment bolt\n3) Selector switch pin seal or kickdown pin seal\n\nNow that is all hospital clean down there I may be able to actually see where the oil is coming out.\n\nStay tuned.\n\nRobC
Posted: Thu Jul 25, 2019 12:39 am
by Ryemaddamazin
Got a similar problem. No power at all to ignition and tranny stuck in neutral. Ahould i mean green and toothbrush trans. Or what help please
Posted: Wed Jun 24, 2020 7:59 pm
by Mountainmade
I'd make sure the linkage isn't rusted up, but if it isn't that... I don't think anything shy of a rebuild would fix it.
