Onan muffler and tailpipe missing
- Travco Model: 1975 320
Not really sure why they are gone. The prior owner said the owner before him had installed a different generator and hadn't finished the job. Not sure exactly what I need, since the old one isn't there to go by. I saw a CL ad for a '78 320 tonight and it had a pic of the generator (posted), and what I bet is the style of muffler and tailpipe I need to find.\nFrom an Onan parts manual it looks like the muffler may be 155-1258, which I can find on ebay.\nAnybody have any ideas on the strange tailpipe and bracket(s)?
1975 Travco 320
Re: Onan muffler and tailpipe missing
On my 4000 CCK the tail pipe was just a piece of threaded Iron Pipe .
I would think you could fabricate that . Advance Auto sells some 1 1/2 ex pipe. IIRC the Muffler is big bucks.
If you really want to get fancy, you could even take it to a muffler shop and have them make an exhaust pipe for it.
One of the ebay sellers (PartsatCurtis) confirmed 155-1258 as the right number. Also said the tailpipe is obsolete.\nSo, I'm going to get the muffler from PartsatCurtis and have my terrific muffler shop build the tailpipe.
1975 Travco 320
- Travco Model: 1976 270
Newby questions:\n\nIt looks like the whole generator mount and assembly slides out. How do I do this? Is the "Control" latch on the front the one that allows movement or what?
Unless you have something I have never seen the Generator does not slide out on a 270. It has 4 bolts that hold it down and very very heavy. If you have the 5 or 6k genset it took 3 guys to lift mine. I was able to do the 4k myself with my skidsteer and alot of four letter words.
- Travco Model: 320
320's generator (on mine) does slide out. That picture posted is correct for a 320 model muffler set up, mine is still intact and looks exactly the same
\nI learn something new everyday... I still have yet to see a 320 in person.7d6 Travco wrote:320's generator (on mine) does slide out. That picture posted is correct for a 320 model muffler set up, mine is still intact and looks exactly the same
