floor soft spots
Unread postby Zed on Sat Feb 10, 2018 5:39 pm
Got a few small (1/2 sq foot) soft spots in the front corners where i guess the front wheels threw water onto the plywood. I am not going to rip it all out, too muvh work. Has anyone here done the trick where you drill out hole in the plywood half way through and then injected epoxy? Probably going to go this route for a quick fix. Anyone done this?
Zed
Travco Model: 270 Mahal
Re: floor soft spots
Unread postby rjsdotorg on Sat Feb 10, 2018 11:45 pm
There are good, albeit expensive, epoxy kits that soak into the (dry) wood and repair wet or dry rot. We used them in showers in homes to avoid big tearouts.
rjsdotorg
Travco Model: 1972 270
Unread postby 77Travco on Tue Feb 13, 2018 12:55 pm
Maybe attach (sandwich style) a new support piece either from the bottom or top?
Return to All other interior
