Do these turn into a bed?
Cabinets, Woodwork, flooring ideas Wall panels etc.
Travco Model: 1976 Travco 270
Unread post by ajeffers » Mon Feb 02, 2015 7:58 pm
76 270, they look like they fold out, how?\n\n
Re: Do these turn into a bed?
Unread post by 77Travco » Mon Feb 02, 2015 8:43 pm
Yes, yes they do. You may need to reach in and defeat the latching mechanism then lift the lower section as the whole thing moves towards the center as it goes flat. If you have a rear booth... that also turns into a bed and/or vise versa. The couch also lifts up and turns into bunkbeds, the top bed has seatbelt looking latches that go to the loop hooks in the ceiling.
Unread post by ajeffers » Mon Feb 02, 2015 9:10 pm
Mine seems to have never had the top bunk installed. The ceiling hooks are there, but it looks like there never have been any hinges in the bulkhead.
Unread post by KB2CRK » Mon Feb 02, 2015 10:23 pm
The back of the couch has the hinges behind it.
Unread post by 77Travco » Tue Feb 03, 2015 10:11 am
Try pulling the back of the couch away and up from the wall. It will unfold and should have two seat belt straps that clip to the ceiling eye hooks.
Unread post by ajeffers » Tue Feb 03, 2015 11:51 am
There is no back.
Unread post by 77Travco » Tue Feb 03, 2015 1:06 pm
Oh, ok... Well, here are a few pics of my couch to help you see what I am talking about in case you ever run across one.
Unread post by ajeffers » Tue Feb 03, 2015 1:42 pm
I've been perusing your photos for a week and no dice, it just never existed on this particular RV
Unread post by KB2CRK » Tue Feb 03, 2015 4:40 pm
If the hooks are in the ceiling it had it at one time. Nessie never had one and does not have the hooks. I do have the back of a couch out of a 69 complete with hinges. I am going to try something with it when I get further into my interior remodel. If that does not work I will most likely let it go to another Travco home.
Travco Model: 1976 270 Rear Bath
Unread post by tcharters » Sun Mar 15, 2015 9:31 pm
Greetings!!! Did you ever figure out how to get those seats to fold flat? I have the same seats in mine, and they slide forward and only go about half way flat. I cannot figure out how to get them to fold all the way down.
Return to “All other interior”
