Level Probe wiring on Black water and fresh water tank.
Unread postby KB2CRK on Wed Mar 11, 2015 10:43 am
Does anyone know the wiring on the level probes for the black water tank? My black water tank was not wired up when I pulled it out so I have no idea what goes where. If someone knows it would save me a lot of time trying to check one wire combo at a time. The fresh water tank is also unwired but at least there the left the ends of the wires connected to the tank so I have something to go by.
Any help is greatly appreciated.
Thanks
Paul
Re: Level Probe wiring on Black water and fresh water tank.
Unread postby 77Travco on Fri Mar 13, 2015 10:59 am
All I can offer is an old picture of my blackwater tank. (see below) I doubt it will help you much though.
Unread postby KB2CRK on Fri Mar 13, 2015 2:58 pm
That works quite well.
It should be about the same from 76 to 77.
Thank you very much
Unread postby Acesneights on Sat Mar 14, 2015 7:00 pm
I have owned several Travcos and yet to see one work so don't get your hopes up.. :mrgreen:
That pic is different than the ones I have had though.
Unread postby badbillybiker on Sun Mar 15, 2015 8:13 pm
wouldn't it be feasible or should I say practical to just buy a new fluid level kit and be in total control of the level readings?
Looking for opinions and options to get around poor or non working gauges and available kits..
Unread postby KB2CRK on Sun Mar 15, 2015 8:42 pm
My tank is different but that is the same probe set up.
Unread postby 77Travco on Mon Mar 16, 2015 10:15 am
Just for the record... both of my holding tank level indicators work. knock on wood.
Unread postby KB2CRK on Mon Mar 16, 2015 10:51 am
Considering I have the same probe setup it should work when I reconnect them. I will be putting the tank back in in a few minutes...
Thanks again 77.
Return to All other interior
