1970 Travco 220
1970 Travco 220
It was in my family since new. I really don't want to cut it up. It needs major welding in the floors, batt box gen box etc. Body has usual gelcoat cracking but doesnt look too bad. Interior needs re doing. It has 40,000 original miles. The gas is rotten in it but I have it running good on a gascan. The brakes are out but I think fliud could be put in and bled. The stuff was all replaced of a few years ago. The tires are cracked. it could probably make a 45min to 1 hr trip max.\n500$
Re: 1970 Travco 220
Can you please tell me where the 1970 Travco 220 is located? Thanks for taking the time to build \na site for Travcos!\nWe have a 1971 Travco 270 that we've been working on for a few months but it's pretty slow progress\nin the winter in South Dakota.
Re: 1970 Travco 220
Thanks.Welcome !! Members will make it great too. Travco owners are a special breed.\nThis one is located in NE Ct 06076\nI also have a 1972 and 1974 that are going up soon.
Re: 1970 Travco 220
More detail.\nThe brakes are currently not working but I will attempt to get them working. The shoes and wheel cyls were all replaced about 7 yrs ago. it had brakes until very recently so could probably fill the master and bleed it. I'd be willing to try. The engine runs excellent. The rig has 40k miles original.\nTranny is good. The tires are badly cracked but I can scare up a set that are not cracked.\nI have the drivers side floor torn apart. it is badly rusted, I can put some plywood in and fasten the seat back down to make it drivable. The exhaust is in good shape. The gas needs to be drained. I have been moving it around with a portable gas tank but I can drain the tank. it has a drain plug. Basically with a little work it should be able to make a 2 hr or so trip. More than that...ehhh maybe. It has been sitting. I drove it form NY to CT about 3 yrs ago with no issues.\nIt has factory dash air. The glass is all good. The bathroom is orn out but I have everything. The cieling was replaced years ago with composite plastic so it is not water damaged but needs a good cleaning. No fridge. it was shot. No genset.. Seats are in good shape, just need cleaning. the batt box/storage is rusted out badly. The frame is good but needs cleaning and paint. some of the steel ribbing that attaches to the fiberglass should be replaced. The body is in good shape save for the usual gelcoat spider cracks.\nI could part out the motor and glass for way more than I am asking but I really want someone to save it.
