Hello from Georgia
Re: Hello from Georgia
Oh yeah, found the VIN in the first place I looked. It was right were you said it was. She is fully registered.
I looked in my library and found ONE floor plan for a rear dinette mahal... HTH..\nThere are most model wiring diagrams at this site.. Just have to snoop a bit...\nThe bathroom I had and the one illustrated for your mahal was a stand over the \ntoilet arrangement. As there is only so much room/floor space they did a lot of \njiggling. In my current model, a 74, I have a full stand in/up shower with out the flex\nhose attatched to the top of the bathroom faucette..but lost cabinet storage space \nand elongated seperate beds in the rear with a small center night stand... I have a \nrear dinette now giving up the longer beds. Win some/lose some.\nBBB
The fuel tank in my 77 270 is 70 gallons. I had it out recently and measured it. I then put the numbers into a fish tank gallons calculator and came up with 72 gallons.\nMy dash air doesn't blow cold so I just run the genset and roof air when driving in hot weather... it works pretty well for me.\nMy coach has the rear dinette setup also but I don't think its a Mahal. I have mine registered as an antique vehicle.
Can you see the or do you know the model of the genset? \nI believe if it's a OCCK model there is already a PDF manual one posted for that unit...FWIW\nBBB\n\nFWIW & My $.02 worth of chit chat...:\nA MAHAL model AFAIK has the door in the center of the Travco... \nCertain Mahals also have a 2+2 emblem on the passenger side only, next to or below the Two-Seventy emblem.\nIn the 270 Mahals they came with a cone style easy chair ... \nThe 220's (Certain models) 290 & 320 I believe all have/had center located door.\nThe 210 & 270 have the FLXIBLE style rounded rear. The 220, 290 & 320 & up all are/were flat backed...\nAFAIK\nSubject to corrections.
@BBB... Sounds right to me.
Here is a ONAN CCK PDF File... While it's not the exact manual, it should get you going.\nI really was looking for my OCCK B manual, but like a lot of things, I'm sure I put it where\nI would remember... CRS...HTH\nBBB\nWhen I locate what I am sure is a closer manual, I will post it as a PDF or I will ZIP it...\nBBB
Here it is 2 years since I bought Nessie home and from the day I joined the Forum. What is interesting about today is that I am working on Nessie getting her ready for our next trip to St George Island FL. Behind the eight ball to start having to repair some wiring on the engine due to our Dachshund chasing out cat up into the engine compartment and having a war in there. Moved her onto the driveway and letting the headers cool so I can put the wiring back together without burning the hell out of my arms.
