Kingpin Part Source Needed
Welcome...
\nStop here first and tell about yourselves...
Travco Model: 1964
Unread post by lauratravco27# » Mon Oct 11, 2021 12:27 pm
We have a 1964 Travco. My Goodyear tire folks say I need the following parts:
Kingpins with 2 grease seals
Tie rod ends
Tie rod tube
Rt side rear spring eye bushing
drag link end @ pitman arm
drag link end @ akerman arm
They can't find the parts. Does anyone know of a source?
Thanks, Dan
Re: Kingpin Part Source Needed
Unread post by KB2CRK » Wed Oct 13, 2021 6:01 pm
Alretta truck parts could be a place to try. For the rear spring bushing any truck spring shop should be able to source one. There is a parts list in the parts section of the forum with part numbers for some years
Unread post by Acesneights » Thu Jan 13, 2022 2:22 pm
I have a complete used axle from a 270 with disc brakes in Ct. I would not waste time with Alretta. He is no longer an actual business and last time I talked to him his attitude was these are old and we should get rid of them. Try a local heavy truck parts place but don’t get your hopes up. As time goes on we will be retrofitting newer axles into these campers.
Return to “New Members Introductions”
