Bathroom Window
Bathroom Window
My bathroom window glass was replaced with Plexiglas at some point in the past. It is siliconed shut and non-operational. I would be very interested in buying a window assembly or glass if there is one out there. Thanks for reading!
Re: Bathroom Window
Ah crud. I just looked at one the other day that was getting junked. Post up the measurements . IIRC the kitchen and door windows are the same except for the privacy glass. Those I have a few spares of.\nLooking at the pic I am betting it's the same. As long as you don't care if it has privacy glass I can send you one.
Re: Bathroom Window
It measures 14" high x 27 7/8" long when measuring to the outside of the metal frame.\n\nJust let me know what you want for it. I have a paypal account or I can send you a money order.\n\nI am getting ready to paint the coach and I would like to take care of this issue first. I am not worried about the privacy glass but I would like to be able to open the window sometimes.
Re: Bathroom Window
I'll measure it but I think that is what I have.
Re: Bathroom Window
No good. Thy were both solid not sliders and 14 1/2 x 28 1/2.\nAll is not lost though. I have to go back to one I looked at last week that is getting junked. I'll see it I can grab that window.
Re: Bathroom Window
You know honestly...I would look at just getting a newer style window that screws in flush. The factory windows on these things leak like sieves and parts are not available. There is no advantage to the original windows other than nostaglia and these things are all that valuable that changing a window style is gonna break it's value. Besides the early 70's ones had screw in windows anyway. You could probably find one a hair bigger from an RV salvage yard then just cut the hole bigger and re frame it with wood. They no longer make the window gaskets and the closest ones I could find from Trim Lock don't radius that well. I changed the gasket on mine and honesty...It turned out like crap and I am experienced in glass. Your original gasket will probably crumble as soon as you try to remove it unless it's been changed.\nI would love to toss all the windows in mine for newer ones but the cost for the big ones is pretty steep.
- Travco Model: 73 and 71
Re: Bathroom Window
Send me the measurments and a photo I may have one!\nhandyguynyc@yahoo.com -Ron\nPS am looking for a radiator for a 73 270 travco and a wiring harness
Re: Bathroom Window
It's the window circled in the picture up above... It measures 14" high x 27 7/8" long when measuring to the outside of the metal frame.
