Stove hood vent filter (Aluminum mesh)
Unread post by badbillybiker » Sun Apr 09, 2017 4:27 pm
Noticed mine was gone... the PO had removed itt. \n1974-270 \nRoughly 10x10x1/8 or 1/4" thick.\nLooks like the brand name on the hood is STRAWSINE.\nAnyone have a spare one they want to off????\nThanks...\nBBB \n04/09/17
Travco Model: Mahal 2+2
Re: Stove hood vent filter (Aluminum mesh)
Unread post by dodgetimes2 » Wed Apr 12, 2017 12:47 pm
Might have luck here, http://www.hoodfilterfactory.com/ Assuming you're looking for the grease filter thingie.
Unread post by KB2CRK » Wed Apr 12, 2017 3:30 pm
I could use one of those.....
Unread post by badbillybiker » Wed Apr 12, 2017 6:33 pm
At this time they are closed... Wiill call tomorrow. Might be the place for the correct unit. \nI just ordered and recieved a NUTONE ALUMINUM hood vent filter #27862 range kitchen\nstove replacement. After I got it , it was all wrong dims, So,, do not order a nutone..\nnot worth sending back....Always looking for part numbers... \nWill keep on until i get it right...\nThanks DODGETIMES2\nBBB
Return to “Want to Buy”
