wanted late sixties 270 travco
Unread post by dodge440 » Sun May 13, 2018 6:25 pm
HI im looking for a 270 travco can be up and running or a minor project ? but open to any post that come to me as a option to buy the right RV \nthanks
Travco Model: 1969
Re: wanted late sixties 270 travco
Unread post by BillDesJardins » Fri May 18, 2018 11:00 pm
Hi,\n\nA friend of mine has one. We do not know the model or year.\nEngine runs. It has been stripped by previous owner. He towed it to his place to save it.\nWe have it posted here. Do you have any information about what year and model it is?\n\nhttps://providence.craigslist.org/rvs/d/dodge-travco-rv/6579751355.html
Unread post by KB2CRK » Sat May 19, 2018 6:42 am
The year is not easy to determine without the vin. It is between a 69 and an early 73 Travco Mahal. If it is a 69 it will most likely have a 318 ci engine. after that the possibility of a 413 is more likely. From the door location I would say it is a Mahal 2+2 which was very similar to the 270.
Travco Model: 1969
Unread post by BillDesJardins » Sat May 19, 2018 11:43 am
Thank you for the baseline information\n73s\n\nBILL W1ZY
Unread post by dodge440 » Mon May 21, 2018 3:43 pm
Bill \nhi thanks for the listing is the interior still with the travco ?\nhave you made any more inspection of it since putting it on line \nI would rather buy one that is complete really even though it needs work \nthanks
Travco Model: 1969
Unread post by BillDesJardins » Tue May 22, 2018 4:54 pm
Hi. No further inspection\nLooking for VIN at this point any suggestions where it is located?\nIt was stripped when we found it and towed it to safety.\nSorry if that is not optimal for your needs.
Unread post by dodge440 » Tue May 22, 2018 5:32 pm
bill hi they do have a chassis stamping [vin] right front outside chassis rail above the leaf spring \nim not sure of a location of a vin plate ,I would try like most dodges drivers pillar .top of dash \netc ,any chance of some pictures
Return to “Want to Buy”
