front turn signal assembly
Posted: Wed Feb 04, 2015 2:33 pm
I am looking for a front turn signal assembly for my 76. The left one I have is almost rusted through and needs to be replaced.
Re: front turn signal assembly
Posted: Thu Feb 05, 2015 11:20 am
Think i found a set on the Travco facebook page.
Posted: Thu Feb 05, 2015 1:12 pm
I looked through my parts box but I already knew I didn't have that.
Posted: Fri Feb 06, 2015 12:20 pm
I am unable to "see" the parking lights... How do I get to the Travco FB where these items are listed/posted?\nBBB\n\nAnyone know which window on my 74 is the knockout/fire escape window for emergencies?...
Posted: Fri Feb 06, 2015 1:14 pm
by RobC
There's a facebook page?!\n\nThere's a knockout/emergency window on these beasts?!\n\nWhere have I been?
Posted: Fri Feb 06, 2015 3:21 pm
Billy, I had posted a wanted on the travco lovers FB page and received a Private message about a pair.\nRobC, My emergency window is the rear glass.
Posted: Fri Feb 06, 2015 4:00 pm
TNX... I had some pics collected from way back and Travco of the day had a rear window marked Emergency and I believe it had a wire embedded in the rubber window molding with a small loop handle and a notice on the window indicating that it was the Fire Escape window.... ripping or pulling the wire cut or weakened the rubber seal enabling the window to "pop out" or be easily kicked out...\nDont remember seeing that indication on my Travcos and do NOT see any type of wire for a quick egress....and was wondering WTF if I was in the back and a fire? (I cant cook) broke out.\nAsking questions that I dont have knowledge of or the answer being snowed in I start thinking too much.. Guess for me n my pups, kicking the glass out is the answer.... wasnt sure... sure hope I have boots on when it (hopefully not) happens...\nDon't see anything about an escape or see any wire....\nBBB
Posted: Fri Feb 06, 2015 4:11 pm
Billy, There is a red loop at the bottom of my rear window and it is marked as the emergency exit. You are correct about the wire in the rear window seal that pulls out. Be a shame to pull it as I believe replacements are not available.
Posted: Sat Feb 07, 2015 1:00 am
My 270 has a metal ring at bottom of the rear window. There is an "Emergency Exit" sign under it.
